JCP Posted November 13, 2022 Share Posted November 13, 2022 Hi all, does anyone have experience of a dashcam install in a G31. The only front fuse box I can locate is on the driver's side and annoyingly there are no fuse diagrams in the car so I can't even work out which fuse is which. I was hoping for easier cable routing there would be one on the passenger side like my previous F11 but if there is, I can't find it. Quote Link to comment Share on other sites More sharing options...
Matthew Posted November 13, 2022 Share Posted November 13, 2022 3 hours ago, JCP said: Hi all, does anyone have experience of a dashcam install in a G31. The only front fuse box I can locate is on the driver's side and annoyingly there are no fuse diagrams in the car so I can't even work out which fuse is which. I was hoping for easier cable routing there would be one on the passenger side like my previous F11 but if there is, I can't find it. Use fuse F59 in the offside front fuse box. Install a fuse piggyback for the connection. I did this on my 6GT a few years ago (same electrics as the G31) and it works perfectly. I removed the cover on the rearview mirror and the offside A Pillar cover and tucked the hardwire wiring along the headlining and down that pillar which leaves a very neat installation. Quote Link to comment Share on other sites More sharing options...
JCP Posted November 14, 2022 Author Share Posted November 14, 2022 Perfect, thanks Matthew. I have ordered a new fuse diagram card but it comes from Germany and will take a week to arrive apparently 🙂 Quote Link to comment Share on other sites More sharing options...
