RichardP Posted October 25, 2022 Share Posted October 25, 2022 I don't suppose anyone has the wiring diagram for the KBA 9540 immobiliser that was used before EWS became standard? This is the system that has a thin rectangular fob that you have to touch an illuminated button to the side of the cluster to disarm. I would guess it was a dealer fit option judging by the way the module is just stuffed behind the drivers side (LHD car) footwell trim. I want to remove it to fit a more modern system and also because it's a pain to use and I only have one fob, if that fails I'll be a bit stuck. Quote Link to comment Share on other sites More sharing options...
Sir Anthony Regents Park Posted December 27, 2022 Share Posted December 27, 2022 I only have the BMW diagrams etc for the actual alarm systems like 2T, 3G etc. That immobiliser (System II) is just to prevent the engine from starting (multiple start interrupt) so will be easy to remove. Just follow each wire from the control unit to where it's spliced into the car wiring loom, cut it if soldered in or if it uses connectors, just unplug and reconnect the original wires. 92-95 cars use EWS1 which takes signals from the central locking via the body control module. When the car is locked, the body control module gets a signal from the switches on the front door handles cut power to the starter and fuel pump. EWSII arrived Jan 1995. Quote Link to comment Share on other sites More sharing options...
