Andrew Posted August 25, 2022 Share Posted August 25, 2022 To help with the running of your BMW, this site https://www.realoem.com/bmw/enUS/select is a great source of information. All you need is to simply enter your the last 7 digits of your chassis number, (which if you are a geek like me, you will still remember all the last 7 digits of each BMW chassis numbers that you own) in to the Serial Number box. For example BV18784 was my E39 chassis number 1 Quote Link to comment Share on other sites More sharing options...
JohnH Posted September 7, 2022 Share Posted September 7, 2022 I must admit that I prefer http://bmwfans.info/ If you change the currency from USD to EURO you get fairly accurate trade prices. Quote Link to comment Share on other sites More sharing options...
Matthew Posted September 7, 2022 Share Posted September 7, 2022 On 25/08/2022 at 13:09, Andrew said: To help with the running of your BMW, this site https://www.realoem.com/bmw/enUS/select is a great source of information. All you need is to simply enter your the last 7 digits of your chassis number, (which if you are a geek like me, you will still remember all the last 7 digits of each BMW chassis numbers that you own) in to the Serial Number box. For example BV18784 was my E39 chassis number REALOEM is my go to site for parts for personal use and helping others when part info is needed. Sadly BMW stopped allowing access to their parts catalogue for we mere mortals so REALOEM hasn’t been updated since 2019. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted September 7, 2022 Author Share Posted September 7, 2022 3 minutes ago, Matthew said: REALOEM hasn’t been updated since 2019. Good point Matthew, although if you are lucky enough to have a 2019 or newer BMW, it's unlikely that you would be needing to worry yourself about parts. You just simply call up the dealer and moan. A 9 year old BMW, well, that's a different story.😆 1 Quote Link to comment Share on other sites More sharing options...
Matthew Posted September 7, 2022 Share Posted September 7, 2022 8 minutes ago, Andrew said: Good point Matthew, although if you are lucky enough to have a 2019 or newer BMW, it's unlikely that you would be needing to worry yourself about parts. You just simply call up the dealer and moan. A 9 year old BMW, well, that's a different story.😆 The only concern is that BMW do update their parts from time to time superseding old parts with new and if one has a pre 2019 car but the part was updated in 2020 you’d never know. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 7, 2022 Share Posted September 7, 2022 Yup; RealOEM for me also The 'BMWfans' website is nigh on the same; bar it gives you the Euro prices; but they're regularly wrong as my pal found out recently when he was looking to stockpile a load of OEM bits for his E39 M5 rebuild... He's stuck with Lemforder & TRW via Autodoc as the costs were adding up! Each to their own; but RealOEM is very easy to use and unless you've got a brand new BMW (in which you'll have warranty no doubt0; you'll do just fine 😉 Quote Link to comment Share on other sites More sharing options...
Andrew Posted September 7, 2022 Author Share Posted September 7, 2022 1 hour ago, Matthew said: The only concern is that BMW do update their parts from time to time superseding old parts with new and if one has a pre 2019 car but the part was updated in 2020 you’d never know. You see that's why we let you re-join, to keep me right. D'oh. Quote Link to comment Share on other sites More sharing options...
Andrew Posted September 7, 2022 Author Share Posted September 7, 2022 There is this alternative too. https://bmwsupply.co.uk/ But you need your full 16 digit chassis number which is a bit harder to remember than the last 7 digits. Unless you are sad like me.... 1 Quote Link to comment Share on other sites More sharing options...
Sir Anthony Regents Park Posted November 16, 2022 Share Posted November 16, 2022 RealOEM is infested with pop ups now making it a pain in the arse to use. BMWFans is better. 1 Quote Link to comment Share on other sites More sharing options...
Humour Posted November 17, 2022 Share Posted November 17, 2022 On 16/11/2022 at 09:24, Sir Anthony Regents Park said: RealOEM is infested with pop ups now making it a pain in the arse to use. For Mobile, I agree, but there are ways around that issue. If you install another Chromium based browser (e. g. Kiwi) you can install extensions to it like on the Desktop. Then install "U-block Orogin" and away you go, no more pop-ups and ads on mobile. I cannot fathom why Google decided its smart not to support extensions in Chrome on mobile (Motivated by money no doubt, they make money from ads after all). Sad that RealOEM is no longer being updated. I wouldn't own a BMW without access to such a library. Superseded parts can be found indirectly as searching for the EOL part will cross reference somewhere on a vendor website, but I admit not exactly scientific and will eat up extra time. Hum Quote Link to comment Share on other sites More sharing options...
Changy Posted February 5, 2023 Share Posted February 5, 2023 On 16/11/2022 at 09:24, Sir Anthony Regents Park said: RealOEM is infested with pop ups now making it a pain in the arse to use. Use the duckduckgo browser; it automatically stops the adverts. Quote Link to comment Share on other sites More sharing options...
Kopfjaeger Posted February 6, 2023 Share Posted February 6, 2023 Try the Opera Browser, it has an ad blocker. I don't think I've ever seen an advert when searching RealOEM... Also, I tend to use on a phone or tablet, instead of a PC. Quote Link to comment Share on other sites More sharing options...
Flandy Posted February 6, 2023 Share Posted February 6, 2023 I use opera too, and it works a treat for blocking ads. Quote Link to comment Share on other sites More sharing options...
Sir Anthony Regents Park Posted February 6, 2023 Share Posted February 6, 2023 I use this - much better than Realoem: http://bmwfans.info/parts-catalog/ 1 1 Quote Link to comment Share on other sites More sharing options...
Kopfjaeger Posted February 7, 2023 Share Posted February 7, 2023 I looked at the bmwfans site, but it only lists F07s, with N55s built up to March 2016. Mine was built in November 2016. I've used Realoem and quite happy with it, ad free luckily. It is good that there are options, so worst case you can use both to check, what you're looking for. Quote Link to comment Share on other sites More sharing options...
