skyjawa Posted May 4 Share Posted May 4 Similar to F10-65 I’ve done the air filter, micro (pollen) filters, oil filter and oil. bit weird in that I filled with 6.5 litres, idrive is happy as Larry saying level ok and showing full, but the dipstick is more like low. Left some in the boot to top up if I have to. also need to do the fuel filter, went to take off the under tray to access it but a few of the screws are rusted to feck, hard to get a socket on or socket does nothing - anyone got any tips for getting them out? Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 4 Author Share Posted May 4 9 hours ago, F10-65 said: What should I be looking at before it goes in this July? Strip, clean and lubricate the front brakes. 33 minutes ago, skyjawa said: anyone got any tips for getting them out? Pair of self locking pliers Or drill them out. New ones are cheap as chips from eBay as are the plastic clips they screw into. 1 Quote Link to comment Share on other sites More sharing options...
skyjawa Posted May 4 Share Posted May 4 Rightyo will give that a crack thanks, also have new ones incoming. 1 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted May 5 Share Posted May 5 On 04/05/2024 at 10:31, Percha said: @F10-65 Car oil temp looks correct, I would hope Bimmerlink is not correct, oil pressure and temp readings are dead (are you sure you have it configured for the right car?) I dont use Bimmerlink so cant help you there, I use Bimmer-Tool/Bimmer-Code/ISTA+ NOTE: Oil changes on diesels, oil is always very black nature of the beast.. high compression ratios and EGR into intake to redigest makes oil black within 50miles. Hey Percha, This looks better... I was on the wrong screen before. 1 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted May 5 Share Posted May 5 @Andrew Do you think I'm gonna need a new battery soon? Quote Link to comment Share on other sites More sharing options...
F10-65 Posted May 5 Share Posted May 5 18 hours ago, skyjawa said: Similar to F10-65 I’ve done the air filter, micro (pollen) filters, oil filter and oil. bit weird in that I filled with 6.5 litres, idrive is happy as Larry saying level ok and showing full, but the dipstick is more like low. Left some in the boot to top up if I have to. also need to do the fuel filter, went to take off the under tray to access it but a few of the screws are rusted to feck, hard to get a socket on or socket does nothing - anyone got any tips for getting them out? I did my cabin filter cabin recently too. Change it now at the next oil service. https://www.amazon.co.uk/hz/wishlist/ls/79XFFS4WMS60?ref_=wl_share Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 5 Author Share Posted May 5 5 hours ago, F10-65 said: @Andrew Do you think I'm gonna need a new battery soon? No Eek it out a bit more You really want a proper battery tester to check it. If you do test it make sure you test it direct on the battery posts. If I test mine on the jump start points under the bonnet the results vary wildly but on the battery direct is much more reliable 1 Quote Link to comment Share on other sites More sharing options...
skyjawa Posted May 5 Share Posted May 5 (edited) Added another few hundred ml of oil. Idrive is still happy showing max, but I’m now just below max on the dipstick so happier that it has enough. According to the measure on the side of the castrol edge oil container, it’s now had just over 6.5l… Edited May 5 by skyjawa Quote Link to comment Share on other sites More sharing options...
Steve84N Posted May 6 Share Posted May 6 Towed for the first time on Saturday... 360 miles later I came back with this (my daughter is also called Elise)! Managed 27mpg which wasn't too bad. I wasn't looking for this colour, I wanted a bright one, but by coincidence it's a very close match for the BMW. It's my perfect pair, each offering a different set of attributes. Running individual throttle bodies with carbon trumpets and carbon airbox. Sounds fantastic bouncing off a tunnel of trees through the Cotswolds. 2 Quote Link to comment Share on other sites More sharing options...
RH27 Posted May 6 Share Posted May 6 Engine cover rubber grommets changed. The disintegrated one was on the alternator mount. Parts were an eBay special advertised as genuine. Came in what looked like genuine BMW plastic wallets and part code stickers and after much comparison with the OE parts removed, I think they were actually genuine... Happy bank holiday! Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 6 Author Share Posted May 6 Washed it Even remembered to park the wipers A rinse with the hose to wet it then a power wash before spraying on the Korosol and Autowheel wash do their thing. Power wash rinse, quite a difference and I’ve not touched the bodywork. And of course a snow foam. And another power wash rinse. Still not touched the bodywork. Followed by summer wheels with new Michelin Primacy 3 on the front. Suspension hasn’t settled in this picture so that’s why it looks high. The Chineseium grade centre caps were fitted which weren’t the best fit but they look a lot better than the old ones. 4 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted May 6 Share Posted May 6 18 hours ago, Steve84N said: Towed for the first time on Saturday... 360 miles later I came back with this (my daughter is also called Elise)! Managed 27mpg which wasn't too bad. I wasn't looking for this colour, I wanted a bright one, but by coincidence it's a very close match for the BMW. It's my perfect pair, each offering a different set of attributes. Running individual throttle bodies with carbon trumpets and carbon airbox. Sounds fantastic bouncing off a tunnel of trees through the Cotswolds. A perfect pair that 1 Quote Link to comment Share on other sites More sharing options...
skyjawa Posted May 7 Share Posted May 7 On 06/05/2024 at 14:14, RH27 said: Engine cover rubber grommets changed. The disintegrated one was on the alternator mount. Parts were an eBay special advertised as genuine. Came in what looked like genuine BMW plastic wallets and part code stickers and after much comparison with the OE parts removed, I think they were actually genuine... Happy bank holiday! Funny you should put that, when doing my service I noticed I was missing one - rear left, so ordered some up from Ebay - just waiting for them to arrive! 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 7 Author Share Posted May 7 Did 50 miles on the new tyres today. Car drives so much better on fresh 19” rubber than the older 18” winter rubber. Washed the winter wheels too. Quote Link to comment Share on other sites More sharing options...
skyjawa Posted May 8 Share Posted May 8 (edited) Brake fluid service done, all that’s left now is the fuel filter. fitted new electric window/handle to replace the old vile one, 10 quid delivered from Ali express! It’s a bit more beige! But its not as bad as the photo suggests, and being brand new hasn’t faded like the rest of the car lol! Edited May 8 by skyjawa 3 Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 8 Author Share Posted May 8 2 hours ago, skyjawa said: fitted new electric window/handle to replace the old vile one, 10 quid delivered from Ali express! It’s a bit more beige! But its not as bad as the photo suggests, and being brand new hasn’t faded like the rest of the car lol! Was this the place you got the handle from? https://www.aliexpress.com/item/1005006604238127.html?src=google&src=google&albch=shopping&acnt=494-037-6276&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17859500389&albag=&trgt=&crea=en1005006604238127&netw=x&device=c&albpg=&albpd=en1005006604238127&gad_source=1&gclid=Cj0KCQjwxeyxBhC7ARIsAC7dS38T6omrgw-XPDOyeAXvAdyoUjO-DC2WPxAsKw-GnvtDrOvGIX_LFAQaAg_AEALw_wcB&gclsrc=aw.ds&aff_fcid=4d8a50aacfd147aa9e90f9577239b128-1715191674144-02432-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=4d8a50aacfd147aa9e90f9577239b128-1715191674144-02432-UneMJZVf&terminal_id=d47b18e670e84c34ac9cc34e4bf549c8&afSmartRedirect=y Mine has gone that sticky horrible mucky way, I can clean it but within no time at all its manky again. Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 8 Author Share Posted May 8 So After looking on that website .... https://www.aliexpress.com/item/1005004073977938.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.3.6ceecd2ccd2cTR&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40000.327270.0&scm_id=1007.40000.327270.0&scm-url=1007.40000.327270.0&pvid=43e30ad0-d0ef-4515-9f2f-6bbb4f52da07&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40000.327270.0,pvid:43e30ad0-d0ef-4515-9f2f-6bbb4f52da07,tpp_buckets:668%232846%238110%231995&pdp_npi=4%40dis!GBP!4.68!4.21!!!41.04!36.94!%402103892f17151922940293689efdc0!12000027952288198!rec!GB!!AB&utparam-url=scene%3ApcDetailTopMoreOtherSeller|query_from%3A and double checking on the car.... that I do only have the single button under the mirror adjustment, I pulled the trigger for one. You have to be careful on that website as it wanted to charge me £25 shipping for one handle instead of just over £4! Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted May 8 Share Posted May 8 Does yours not have folding mirrors? Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 8 Author Share Posted May 8 1 minute ago, duncan-uk said: Does yours not have folding mirrors? Nope Which is why it’s a single button cutout needed. Compare my pic to that of @skyjawa you’ll see the subtle difference. Quote Link to comment Share on other sites More sharing options...
skyjawa Posted May 8 Share Posted May 8 (edited) Yeah you do have to watch postage, may be stupid cheap but massive post cost! this is what I got https://www.aliexpress.com/item/1005004149585955.html?spm=a2g0o.order_list.order_list_main.5.6aa31802suv7py Edited May 8 by skyjawa 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 8 Author Share Posted May 8 Thanks @skyjawa, you have model A for the folding mirror button, I need model B without the folding mirror button. Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted May 8 Share Posted May 8 17 minutes ago, Andrew said: Nope Which is why it’s a single button cutout needed. Compare my pic to that of @skyjawa you’ll see the subtle difference. POV spec 🤪 2 Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 8 Author Share Posted May 8 1 minute ago, duncan-uk said: POV spec 🤪 Or as I like to say Less to go wrong spec 😝 2 Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted May 8 Share Posted May 8 Well my mirrors are currently tucked safely out of the way. Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 8 Author Share Posted May 8 Well mine are still attached to my car on my nice safe driveway. Quote Link to comment Share on other sites More sharing options...
