duncan-uk Posted December 18, 2023 Share Posted December 18, 2023 Always good to challenge perceived wisdoms. Helps the knowledge base grow. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 18, 2023 Author Share Posted December 18, 2023 You do need to be careful @F10-65 what you read on the internet about F10s……. ……as most of it is put up there by idiots like me 🤪 No offence taken, no need to apologise, always the right thing to do is to challenge and spark debate. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 18, 2023 Author Share Posted December 18, 2023 Just completed an Autodoc order. oil, brake fluid, brake bleed screws, oil filters, air filters, hub nuts, crankcase breather hose. Just need spark plugs, coils and pollen filters for its major service, thankfully not due that till October. 1 Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted December 18, 2023 Share Posted December 18, 2023 1 hour ago, Andrew said: You do need to be careful @F10-65 what you read on the internet about F10s……. ……as most of it is put up there by idiots like me 🤪 At last something we can agree on 😂 1 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted December 20, 2023 Share Posted December 20, 2023 Wiper blades I ordered these and they fit and work OK but they just aren't as good as the OEM ones I put in the bin. The old ones were silent and seemed to be much more substantial, the new blades are a bit squeaky at times. https://amzn.eu/d/9LNR8Uq But it looks like the OEM part is no longer available so just the blade is left. I hope I'm wrong. RealOEM.com - Online BMW Parts Catalog I'll pop into BMW later today Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 20, 2023 Author Share Posted December 20, 2023 The BMW dealer will want at least twice the price than Amazon do. But the OEM Bosch blades are slightly different from the aftermarket Bosch ones. 1 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted December 20, 2023 Share Posted December 20, 2023 5 hours ago, Andrew said: The BMW dealer will want at least twice the price than Amazon do. But the OEM Bosch blades are slightly different from the aftermarket Bosch ones. So yes Andrew. More than three times the price in fact at £61.25 and they didn't look any different to what I have from Amazon but I hear what you say about OEM. I'll get the most out of the ones I have for now and maybe at the next replacement... Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 20, 2023 Author Share Posted December 20, 2023 (edited) I have the set A524 and have no issues. Yes they were fractionally different from the genuine bmw Bosch ones I removed but they were less than £20 from eBay a few years back. Edited December 20, 2023 by Andrew A524 not A523 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 21, 2023 Author Share Posted December 21, 2023 Got mine booked in today for an MOT on 19th Jan. Might need a new set of wiper blades before then, and rear brakes.... Quote Link to comment Share on other sites More sharing options...
F10-65 Posted December 21, 2023 Share Posted December 21, 2023 3 minutes ago, Andrew said: Got mine booked in today for an MOT on 19th Jan. Might need a new set of wiper blades before then, and rear brakes.... Gonna be chilly out there doing those brakes yourself...Brrr Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 21, 2023 Author Share Posted December 21, 2023 The storm has warmed it up a bit. 10 deg C here today. It was chuffin' wet tho.... Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted December 28, 2023 Share Posted December 28, 2023 Changed 5 out of 6 spark plugs. Why just 5 you ask. Well for some reason I can’t get my socket on No 4. My thin walled socket has worked fine on the others just seems to big on this one. Not sure what the hell ia going on! 🤬 Quote Link to comment Share on other sites More sharing options...
Steve84N Posted December 29, 2023 Share Posted December 29, 2023 @duncan-ukI seem to recall the spark plugs are on varying angles so you have to position the socket differently for each cylinder. Some of them are a bit tricky. Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted December 29, 2023 Share Posted December 29, 2023 On 29/12/2023 at 13:15, Steve84N said: @duncan-ukI seem to recall the spark plugs are on varying angles so you have to position the socket differently for each cylinder. Some of them are a bit tricky. No it wasn't that 1-3,5 & 6 were fine with my socket so something amiss. In better light today (between showers) i compared 1 & 4 to see if they look in anyway different, i used a long length of solder (courtesy of my grandads old tool box) to check depths around the plug i could get in around about half the plug and with a good light thought i could see something. Dab of grease pulled out a shard of black plastic but thought there was more i couldn’t move - whacked hoover on it and heard something come out. Socket now fitted as per the others - suspect at last change the plastc insert of the plug spanner broke? Either way all fixed now. 1 Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted December 30, 2023 Share Posted December 30, 2023 Changed the oil. It’s not done many miles but was due on time. Used icarsoft to resent idrive and car is all good. Needs a brake fluid and pads change in the new year. Quote Link to comment Share on other sites More sharing options...
Steve84N Posted December 31, 2023 Share Posted December 31, 2023 (edited) @duncan-ukhave you got a pressure bleeder? If you have then great, if not then I'd definitely get one. They're cheap and make it so easy. Edited December 31, 2023 by Steve84N Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted December 31, 2023 Share Posted December 31, 2023 Yes i have. Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 31, 2023 Author Share Posted December 31, 2023 Received my AUTODOC order from 18th December @Steve84N, don’t worry @duncan-uk is an expert in bleeding brakes.🤣. He’s done much work on his E39 braking system. 1 1 Quote Link to comment Share on other sites More sharing options...
Steve84N Posted December 31, 2023 Share Posted December 31, 2023 @Andreware you just replacing the axle nuts or something behind? Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted December 31, 2023 Share Posted December 31, 2023 6 minutes ago, Steve84N said: @Andreware you just replacing the axle nuts or something behind? Just the usual bi-monthly rebuild. 1 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 31, 2023 Author Share Posted December 31, 2023 2 hours ago, Steve84N said: @Andreware you just replacing the axle nuts or something behind? Just the nuts to avoid this happening… So it’s not an issue if I ever need in there to do something. The above is on an E92 that is only one year older than mine and from a much drier climate than mine. They were a few quid each so no-brainer. 2 hours ago, duncan-uk said: Just the usual bi-monthly rebuild. Remind me of the work done to all four of your cars this month alone? All mine has needed since putting the winter wheels on (November) has been copious amounts of E5 and screen wash. 😝 Quote Link to comment Share on other sites More sharing options...
Steve84N Posted January 1 Share Posted January 1 You should be fine, mine came off without a fight. 100Nm and 45 degrees isn't too bad. Quote Link to comment Share on other sites More sharing options...
skyjawa Posted January 3 Share Posted January 3 Uploaded the XHP gearbox map at last, chose Stage 3, just completed the running in 50 miles so time to play. Already know I need to change the comfort mode 7th to 8th shift point as it’s hanging on to 7th too long….. Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted January 3 Share Posted January 3 So what does that do? Quote Link to comment Share on other sites More sharing options...
skyjawa Posted January 3 Share Posted January 3 (edited) It does quite a lot of tweaks to the gearbox software, lots of changes are possible, various stages of tune are available, and you can tweak individual settings like torque limits, shift points, smoother changes, more responsive up and downshifts etc. https://rbttuning.atlassian.net/wiki/spaces/RBTTUNING/pages/1212884/xHP+Flashtool+-+Introduction#:~:text=xHP is the only tool,automatic transmission in your hands. Edited January 3 by skyjawa Quote Link to comment Share on other sites More sharing options...
