duncan-uk Posted July 21, 2023 Share Posted July 21, 2023 Yes so most of the preference coding shall we say can be done by Carly or Bimmercode but things like coding new components such as the rack or an ABS module need INPA/ Esys etc? Quote Link to comment Share on other sites More sharing options...
skyjawa Posted July 21, 2023 Share Posted July 21, 2023 (edited) Carly and Bimmercode are great at changing the odd setting, but for new components it can be very difficult to get the right things to change as there can be lots to change. Using esys and vo coding when you code the ECU it automatically changes all settings needed. for the rack I’m not sure if that can be done in esys, might need ista…. edit - looking through a few threads should be able to code the EPS by VO coding in Esys…. Edited July 22, 2023 by skyjawa Quote Link to comment Share on other sites More sharing options...
skyjawa Posted July 23, 2023 Share Posted July 23, 2023 Grrrr. Spoke too soon 😞 All appeared to go ok, got an RDC warning when I next started the car, inialized the system and all tyres went green and no more warnings. It’s now doing it every time I start the car, have to re-initialise each time, occasionally get a couple of RDC Error but will eventually initialise (takes a few seconds to a minute) and never get another warning as long as the car is not turned off. Have to be stationary to initiate the reset still, option is greyed out once moving. may just have to bite the bullet and get new sensors if I can’t crack it…. Quote Link to comment Share on other sites More sharing options...
Percha Posted July 23, 2023 Share Posted July 23, 2023 Changed the cabin filters (x2) and the air filter, all were bloody filthy got the hoover out for both of them! Next job is the oil and filter this week at some point. Then next month rear brake discs and pads. This was also completed on my wifes BMW F20 116D but we dont talk on this variant within this forum do we... Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 24, 2023 Author Share Posted July 24, 2023 14 hours ago, Percha said: This was also completed on my wifes BMW F20 116D but we dont talk on this variant within this forum do we... Well there is a baby section further down the page, if you must drive something that isn’t a 5 Series 🤣 1 Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted July 24, 2023 Share Posted July 24, 2023 It’s ok Percha. Some people have Fords. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 25, 2023 Author Share Posted July 25, 2023 19 hours ago, duncan-uk said: It’s ok Percha. Some people have Fords. But you forget The only reason a lot of us drive BMWs is cos there are no decent rear wheel drive Fords anymore. Cortina, Granada, Sierra, Capri. All rear wheel drive and available with 6 cylinder engines. What are Ford offering today? The hateful wrong wheel drive Puma in hybrid form! Sack that and buy a decent 5 Series for some rwd fun. 1 Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted July 25, 2023 Share Posted July 25, 2023 No I bought and e28 because I didn’t want a rotten Sierra/ Granada / Capri. Quote Link to comment Share on other sites More sharing options...
Matthew Posted July 26, 2023 Share Posted July 26, 2023 18 hours ago, Andrew said: What are Ford offering today? The hateful wrong wheel drive Puma in hybrid form! And then it isn't a real hybrid although many manufacturers are playing with the word Hybrid for these 48v mild hybrid systems. They have a start/alternator combo that can "drive" the car, really to smooth out the start/stop function, and its only real value is reducing CO2s. It does very little for MPG, power delivery or anything else so just another level of complexity and cost. 2 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 26, 2023 Author Share Posted July 26, 2023 Got my 14mm Allen key bit for the diff drain/fill plug. Diff oil should hopefully arrive tomorrow, along with crap weather…. 1 Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted July 26, 2023 Share Posted July 26, 2023 Hosing it down here 🙄 Quote Link to comment Share on other sites More sharing options...
Steve84N Posted July 26, 2023 Share Posted July 26, 2023 @Andrewsnap but 9mm as you'd thankfully highlighted it's needed for the brake caliper slide pins. 😅 Unfortunately the tag snapped when I tried to pull it out so now I have to dig it out. 1 Quote Link to comment Share on other sites More sharing options...
Steve84N Posted July 26, 2023 Share Posted July 26, 2023 I finally managed to find someone to swap my M Performance exhaust backboxes with. It's a small world when it comes to the 535i Touring. It turned out I was swapping with the first 535i I went to see when looking to buy, so I'd test driven it. I walked away because I found after a check it was Cat N and the seller pretended not to know. Someone else bought it and shortly after had to have a full engine rebuild for £7k so I dodged a bullet there. Then that car, a 36k mile 2017, was bought by Dan who has owned category cars before. Dan is the same Dan who owned a higher mileage manual 535i Touring a few years ago. Dan went home happy with a more fruity exhaust and I got his. It didn't go entirely to plan though. With both exhausts off the car mine has nothing until a couple of hangers near the back of the mid section. His had a bracket off the gearbox and no hangers on the mid section. Therefore, we agreed to cut his backboxes off instead of swapping from the cat back. Trouble is we didn't have an extra two 60mm sleeve clamps... We used my existing clamps to get Dan on his way and I was about 20 minutes from home at my mate's garage unit. We fired it up without the backboxes to see if it was not crazy to drive it home. It wasn't! In fact, it was almost the same volume as the M Performance backboxes. On the way back there was a bit more drone but it was clear the M boxes don't do much, other than take out some of the boominess. That explains why it was too much, it was already a bit loud before the sports cat. It's a huge difference with the standard system, barely purrs, let alone any sort of roar. I would have liked something in the middle but of the two I prefer it quiet. I've still got the performance benefit of the sports cat so I'm happy. I prefer the slash cut tips too. You can see how much smaller the M boxes are, there's loads of spare space. Needs some fresh hangers to lift the exhaust a bit. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 26, 2023 Author Share Posted July 26, 2023 1 hour ago, Steve84N said: @Andrewsnap but 9mm as you'd thankfully highlighted it's needed for the brake caliper slide pins. 😅 Yeah until only the last few years, no Allen key sets ever had a 9mm. I think Mercedes use 11 mm hex on their slide pins. I also bought a 17mm and 19mm hex too which are now being used on hub bolts instead of 30 something mm hub nuts. Quote Link to comment Share on other sites More sharing options...
Steve84N Posted July 26, 2023 Share Posted July 26, 2023 I almost came unstuck with large hex sockets when doing my clutch as you need one to remove the part holding the springs back. Luckily I had it from my motorbike days. I've also got the one for the sump plugs. Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted July 26, 2023 Share Posted July 26, 2023 2 hours ago, Steve84N said: We fired it up without the backboxes to see if it was not crazy to drive it home. It wasn't! In fact, it was almost the same volume as the M Performance backboxes. On the way back there was a bit more drone but it was clear the M boxes don't do much, other than take out some of the boominess. That explains why it was too much, it was already a bit loud before the sports cat. It's a huge difference with the standard system, barely purrs, let alone any sort of roar. I would have liked something in the middle but of the two I prefer it quiet. I've still got the performance benefit of the sports cat so I'm happy. I prefer the slash cut tips too. You can see how much smaller the M boxes are, there's loads of spare space. Interesting, can't say i particularly like the noise of the 535i at revs, maybe its the turbo but dont think its BMW's best sounding egine. Quote Link to comment Share on other sites More sharing options...
Steve84N Posted July 26, 2023 Share Posted July 26, 2023 @duncan-ukit's not as nice as the N52 I had in my Z4 and it doesn't rev out very well because the boost drops off a cliff on the PWG pre LCI cars but to be honest it suits the 5 Series, where you use low to mid revs wafting along at pace. Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted July 26, 2023 Share Posted July 26, 2023 I rarely rev mine TBH and i find sport mode a bit frenetic - however clever this 8 speed auto is its not as clever as me. It doesnt know that sometimes i want to rev to 5k then change up and cruise - actually find the 5 speed auto in the e46 is more intune with me. Yes on stop start motorway or in town it has advantages but i am still not a convert! Quote Link to comment Share on other sites More sharing options...
Steve84N Posted July 27, 2023 Share Posted July 27, 2023 I'm inclined to agree and the clutch in mine is so easy it's not even a problem in traffic. Quote Link to comment Share on other sites More sharing options...
skyjawa Posted July 27, 2023 Share Posted July 27, 2023 (edited) Hopefully finally sorted the TPMS! Went through FDL with Bimmercode and all the correct settings were there from the VO coding, read on another forum that even when all that is done on the F10 you need to pull the fuse for the RDC module (fuse 139 in the boot) or unplug it. Pulled the fuse and bingo! No more moaning on start up and iDrive now shows Flat Tyre Monitor instead of RDC 🙂 Edited July 27, 2023 by skyjawa 1 Quote Link to comment Share on other sites More sharing options...
Munzy Posted July 28, 2023 Share Posted July 28, 2023 (edited) Painted the calipers front and rear… Usually like to play it safe and go with dark/graphite grey but decided to roll the dice and try something a bit more adventurous. Brembo Midnight Blue caught my eye so took the plunge. The description said it was almost black until you get up close but it is most certainly blue, very similar to the BMW shade I see on other cars. Used a battery hand drill with various wire wheel attachments, air blower for dust and a can of brake cleaner to wipe them down before paint. Two very thin coats with a soft paint brush (hate to see calipers when the paint has been slapped on!). Job was done with the calipers on the car, if you are careful and use small brushes for the tight parts it looks very convincing when the wheels are on. Rear photos will come when I’ve fitted the new pads and discs - lovely black anti corrosion paint on the top hat bit of the disc looks very neat. (From EBC brakes but apparently they now only come with a grey paint incase anyone is looking). I’m aware of trying too hard with the old girl - I hate seeing classy cars with “chav-grades” such as liberally applied red caliper paint, M-Sport grill strips etc but I think the blue works nicely with the darker wheels on a grey car 😀 Edited July 28, 2023 by Munzy 5 Quote Link to comment Share on other sites More sharing options...
Steve84N Posted July 28, 2023 Share Posted July 28, 2023 @MunzyI like that. I'm due to do a full brake job soon, including caliper rebuild. I wasn't going to bother painting the calipers but you're making me think twice. 1 Quote Link to comment Share on other sites More sharing options...
skyjawa Posted July 28, 2023 Share Posted July 28, 2023 Yeah they look good 👍🏻 1 Quote Link to comment Share on other sites More sharing options...
Munzy Posted August 1, 2023 Share Posted August 1, 2023 (edited) Completed the job on refreshing the brake calipers by applying some M-Sport decals. Went with silver M instead of white or grey. Decals were next day posted from the link below. Came with a reassuringly comprehensive and well written instruction sheet and positive reviews. I certainly won’t be torturing the old Princess round a track any day soon (ever) but hopefully the decals and paint job will stand up to the day to day driving I do. https://www.ebay.co.uk/itm/351208651614?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=DTN4CYZZRBO&sssrc=4429486&ssuid=q3CRNO_XRmG&var=&widget_ver=artemis&media=COPY Edited August 1, 2023 by Munzy 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted August 1, 2023 Author Share Posted August 1, 2023 As a local enough lad to you @Munzy, where did you get the wheels powder coated? Mine could do with re-doing nearly 7 years later. Quote Link to comment Share on other sites More sharing options...
