Steve84N Posted June 30, 2023 Share Posted June 30, 2023 The Gotthard tunnel had a very long queue so we did the pass, it was spectacular and a perfect place to stop for lunch with a view. Now in Metz, France before we get home tomorrow. 7 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 1, 2023 Author Share Posted July 1, 2023 It’s that time of year again when mine is due it’s annual yellow grommet inspection and clean out. 12 months worth of muck. I did it in between showers this morning, when I loosened the cover water trickled out. It had been very wet overnight and early this morning here and you can see the tide line on the back of the cover. 4 Quote Link to comment Share on other sites More sharing options...
Percha Posted July 1, 2023 Share Posted July 1, 2023 @Andrewyou should modify the cover as others (and myself) have, then you wont get that tide line on an overnight downpour. 1 Quote Link to comment Share on other sites More sharing options...
VPCAPTAIN Posted July 1, 2023 Share Posted July 1, 2023 @Percha hi and whats the cover mod ? will be cleaning out my grommet in the next few days, similar schedule to @Andrew every mid summer, hopefully no nasty suprises but i do have a new grommet ready to fit if needs be thanks Quote Link to comment Share on other sites More sharing options...
Cadwell Parker Posted July 2, 2023 Share Posted July 2, 2023 5 hours ago, VPCAPTAIN said: whats the cover mod ? Cut away a section of the seal at the bottom of the cover to allow water to drain and avoid it pooling behind the grommet. This way any water should be able to drain straight through rather than pooling and finding its way into the car. 1 2 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 2, 2023 Author Share Posted July 2, 2023 15 hours ago, Percha said: @Andrewyou should modify the cover as others (and myself) have, then you wont get that tide line on an overnight downpour. I have wrestled with that idea, but I’m happy to annually go in and inspect clean out the area, and of course as long as the near side scuttle drain is kept clear as that’s where the water drains too via that square cut out. Quote Link to comment Share on other sites More sharing options...
olliecampbell Posted July 3, 2023 Share Posted July 3, 2023 On 13/06/2023 at 01:21, Steve84N said: ... Digging up quite an old picture here, but @Steve84N what model are your car lifts? And how well do you find them to work? Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 3, 2023 Author Share Posted July 3, 2023 First Monday of the school holidays up here today. So that transpires to having the wipers on full speed and the heated seat on as it was only 10.5 deg C this morning when out in mine. Was needing my winter tyres for the flooding on the roads...... Quote Link to comment Share on other sites More sharing options...
Steve84N Posted July 3, 2023 Share Posted July 3, 2023 (edited) @olliecampbellI've got the Quickjack 5000SLX. I had to buy their frame extensions to reach the 5 Series jacking points. The good news for you is they have now replaced the SLX models with the TLX version, which has 3" more of lift. They also do a longer version to save having to get the extensions. This is what you would get: https://www.quickjacklift.co.uk/car-lifts/5000tlx/ It is powered by the car battery and works very well. There's two lock points so it rests on mechanical steel and not the hydraulics. I'm fine to go under on a trolley, although another 3" would make a helpful difference. They don't get in the way of stuff in the middle underneath like a lot of lifts do. The only thing I've found is one of the bolts on the rear underbody braces is covered up on the lift, but it's easy to undo before jacking it up. Overall, I'd recommend it as a safe and secure way of getting the car up. It's so much better than jack stands. Each lift is north of 30kg but they have small wheels to move them around. For small jobs like swapping wheels I still use a simple jack but for everything else it's worth it. Edited July 3, 2023 by Steve84N 2 Quote Link to comment Share on other sites More sharing options...
olliecampbell Posted July 3, 2023 Share Posted July 3, 2023 Perfect thanks @Steve84N I have a soft uneven gravel driveway and hate going under axle stands. Until I get the garage built I'm always looking for ways of getting the car up more easily and safely. These might be an option I guess. Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 3, 2023 Author Share Posted July 3, 2023 1 hour ago, olliecampbell said: These might be an option I guess. I have a pair of these https://cjautosheywood.co.uk/product/heavy-duty-scissor-hydraulic-car-ramps-1360kg-cr06xhd/ Great for suspension work when the weight of the car needs to be on its wheels so that the suspension is at the correct ride height. Mechanical lock too so you don't (must not ever!) rely on a hydraulic valve to hold the car above you. Plus these can be easily used with axle stands. Happy to set up a gofundme page for another pair. Very substantial which is what you want when you are under the car. Quote Link to comment Share on other sites More sharing options...
Steve84N Posted July 3, 2023 Share Posted July 3, 2023 @olliecampbellthese would work as they spread the load out. It's a square tubular construction and would be supported on gravel, although you might want some boards underneath for added stability/less paint scratching. Quote Link to comment Share on other sites More sharing options...
olliecampbell Posted July 4, 2023 Share Posted July 4, 2023 Perfect thanks gents. I'll keep them both in mind for when my bank account has stopped doing a drain impression. 1 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted July 5, 2023 Share Posted July 5, 2023 Mine was MOT'd this morning. Passed but the front brakes have an imbalance of 43% and the limit is 50. They just advised. Is that likely to be a sticky caliper or piston that I could service myself? Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 5, 2023 Author Share Posted July 5, 2023 2 hours ago, F10-65 said: Is that likely to be a sticky caliper or piston that I could service myself? It could be but as an easy starter for ten... Strip brakes and examine the caliper piston seals. They should be soft and pliable around the piston where it seals into the caliper body. Not tears or distortion. Clean the caliper cradle where the pads slid over, wire brush, file loads of brake cleaner. Put a bit of ceramic grease on the contact points when the pads slide on the cradle Give the caliper slide pins a good wire brush too. Try to retract the piston back into the caliper with a G clamp or specific tool, do this with the bleed nipple open to check that it will move. Shut nipple re-assemble and pump brake pedal a few times to re sit the piston on the pads. You can buy caliper refurbish kits which will include new seals etc, but if there is internal corrosion (caused from water in the brake fluid) in the bores of the caliper, you might be onto plumbs and a new caliper is needed. Quote Link to comment Share on other sites More sharing options...
Neilos100 Posted July 5, 2023 Share Posted July 5, 2023 So all the bits arrived for the rear dampers except the top mounts...and they should arrive tomorrow or Friday. Hopefully by Monday it'll all be fitted. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 5, 2023 Author Share Posted July 5, 2023 Got my new sump plug, sump plug washer and diff plug from Cotswolds today. Quote Link to comment Share on other sites More sharing options...
0011718 Posted July 7, 2023 Share Posted July 7, 2023 Had my valve cover gasket replaced, and also a split breather pipe replaced! Quote Link to comment Share on other sites More sharing options...
skyjawa Posted July 9, 2023 Share Posted July 9, 2023 New (to me) wheels arrived. 613m 18’s to replace the horrible 236 17’s. They are just too small for such a big car and not a fan of the style. I know it’s only an inch bigger but much more aesthetically pleasing to my eyes, and didn’t want to ruin the ride quality or cost of tyres by going any bigger. just in the process of tidying them up inside and out, then will get them fitted. 5 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 9, 2023 Author Share Posted July 9, 2023 I like the 613m wheels. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 11, 2023 Author Share Posted July 11, 2023 This arrived to help me with my diff oil change Just need to source a 14mm Allen key for the fill plug. Oh and some diff oil…. Quote Link to comment Share on other sites More sharing options...
Munzy Posted July 12, 2023 Share Posted July 12, 2023 (edited) The Princess turned 150k today! 😍 Oil and filter change done. I’ve used an electric pump (£15 from Lidl) for a while now (did one sump plug drain last year) and have read many opinions on whether or not those pumps gets as much oil out as a sump drain. Today I ran the car up to temp then used the pump to get as much as it could suck out. I then lifted the car, undid the sump plug, lowered the car back down and collected what came out - which was about 20ml - dribbles. I also compared the consistency and, as far as I could see and feel, it was the same as what had come out of with the pump, with no sludge or bits (thank god!) So a negligible difference between the methods in my opinion. The pump is just so much quicker, easier and less mess for me. If I was feeling rich (which these days I don’t) I would like to get a few extra litres of the oil I use and flush it through the engine with the sump plug removed but that will have to wait until another day. After the recent drama with the mystery coolant leak and me worrying she may be a ‘gonner, I took her for a spin down to the coast revelling in her class, freshly poured oil and treated myself to a a haggis supper and a cone 😀 Edited July 14, 2023 by Munzy 6 Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 13, 2023 Author Share Posted July 13, 2023 8 hours ago, Munzy said: treated myself to a a haggis supper Yummy. Plus the labour you have saved doing the oil change yourself will almost have paid for that supper. I have almost given up trying to educate the other Admins on here ( @duncan-uk @Alpinaman ) about the delights of Scottish cuisine but have failed miserably so far. Flat sausage is another delicacy that is lost on them..... The newer cars are now being designed for vacuum sump emptying. My wifes Kuga as an example, has the dipstick located centrally in the cylinder head in a tube that leads to the sump, which is right next to the filler cap to make the exercise easy. But the oil filter is buried away meaning you still need to lift the car to access it (unlike our proper cars) so I'm not sure what the benefit is, if you still need to lift the car or go under it which is the risky bit. Quote Link to comment Share on other sites More sharing options...
olliecampbell Posted July 14, 2023 Share Posted July 14, 2023 On 13/07/2023 at 08:35, Andrew said: ...My wifes Kuga as an example, has the dipstick located centrally in the cylinder head in a tube that leads to the sump, which is right next to the filler cap... So they can suck it out, push it through a paper filter and back into the car whilst charging you for new oil? :D Quote Link to comment Share on other sites More sharing options...
olliecampbell Posted July 14, 2023 Share Posted July 14, 2023 On 12/07/2023 at 23:19, Munzy said: ...I also compared the consistency and, as far as I could see and feel, it was the same as what had come out of with the pump, with no sludge or bits (thank god!) So a negligible difference between the methods in my opinion. The pump is just so much quicker, easier and less mess for me. ... I wonder if a little more oil in the sump might have pulled more lumps out with it when you pulled the sump plug. I guess the only way to tell would be to put more new oil through to maybe flush these bits out....Just a thought. Quote Link to comment Share on other sites More sharing options...
