Andrew Posted May 25 Author Share Posted May 25 I got a set of genuine replacement locking wheel bolts from eBay from one of the dealers. I’ve also used Cotswolds for the odd replacement. Just make sure if buying online that the bolts are M14x1.25 and not the older style M12x1.5 bolts. Both have 17mm hex heads so appear the same but aren’t! 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 28 Author Share Posted May 28 Mine turned 66,000 miles this morning So many jobs I want to do on it but can't get near them for work, weather and other domestic reasons.... 1 Quote Link to comment Share on other sites More sharing options...
mullinsj08 Posted May 28 Share Posted May 28 I did the drivers-side door handle yesterday afternoon. Other than that I've ordered some brighter LED boards for the ambient lighting I didn't realise I had until I started mucking about with door handles! 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 28 Author Share Posted May 28 Lol that's on my long to do list too. They call that the "Low-end" Model Just because it doesn't have folding mirrors (more stuff to go wrong) 2 Quote Link to comment Share on other sites More sharing options...
Dimsum Posted May 28 Share Posted May 28 I knew it was coming but almost missed it…. 🙂 3 Quote Link to comment Share on other sites More sharing options...
Andrew Posted May 29 Author Share Posted May 29 On 18/03/2024 at 15:05, Andrew said: Removed the nearside front wheel... and the TMS module which was thankfully bone dry so I could blast the hairdryer into the TMS module opening.... to test the hairdryer theory out for getting rid of the headlight condensation. First thing this morning ...it's clearing up... Getting there 30 minutes of hot air being blown thru, the top cap was open to encourage air flow thru the headlight. I'll take that as a win, well for today anyway. And in a futile attempt to limit its return. We will wait and see how long that lasts. Answer, not that long. Came back with vengeance yesterday. Balls. 1 Quote Link to comment Share on other sites More sharing options...
Rimvyz Posted May 29 Share Posted May 29 Did an oil and fuel filter change today, still going strong with 180k on the clock😇 5 Quote Link to comment Share on other sites More sharing options...
Snakle535i Posted May 31 Share Posted May 31 Upgraded the suspension to a B12 Bilstein set and new bump stops and dust covers on rear shocks. Noticeable difference in how the car now rides a lot flatter on acceleration and braking as well as through the bends. 3 Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 1 Author Share Posted June 1 When I’ve fitted new shocks, you can feel difference within a few hundred meters of driving. It’s a great sensation. Are Bilsteins worth the cash? Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 1 Author Share Posted June 1 Started the under bonnet clean by blowing out the leaves and cobwebs. 1 Quote Link to comment Share on other sites More sharing options...
skyjawa Posted June 1 Share Posted June 1 (edited) Started it after being stood for 2 weeks in the rain. No battery discharging while stationary message so looks like the remaining 2 new comfort access handles I fitted a couple of months ago are working spot on! Edited June 1 by skyjawa 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 2 Author Share Posted June 2 Did the annual yellow grommet check Bit of debris but importantly the yellow grommet looks healthy. Gave the engine bay a quick clean too after splashing water on it from rinsing out the yellow grommet. Followed by a wash and a very quick try of a few detailing sprays. If I had more time ideally it wants a clay and polishing too 5 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted June 2 Share Posted June 2 3 hours ago, Andrew said: Did the annual yellow grommet check Bit of debris but importantly the yellow grommet looks healthy. OMG! Thats a lot of detritus in 12 months. I wasn't thinking to check mine for another few years Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 2 Author Share Posted June 2 52 minutes ago, F10-65 said: OMG! Thats a lot of detritus in 12 months. I wasn't thinking to check mine for another few years Actually just checking back, it was 11 months ago I last did it.... Looking at the photo it looks worse as there were a couple of leaves which makes it look like a bigger mound. It's an annual job IMHO.... I can do it in less than 20 minutes as I'm an expert at getting the cover back on in the right spot so as to get that 4th bolt in the awkward location. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 2 Author Share Posted June 2 On 01/07/2023 at 15:43, Andrew said: It’s that time of year again when mine is due it’s annual yellow grommet inspection and clean out. 12 months worth of muck. I did it in between showers this morning, when I loosened the cover water trickled out. It had been very wet overnight and early this morning here and you can see the tide line on the back of the cover. @F10-65 Post from 1st July last year. More build up in the last 11 months than the previous similar time frame. Although it has been much wetter I reckon and I do park nowadays nearer more trees so more chance for muck to build up. So are you going to look at yours again then? 🤣 1 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted June 3 Share Posted June 3 MOT today. Straight through, no advisories. Eight years and six months old. 102,286 miles on the clock 5 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted June 3 Share Posted June 3 21 hours ago, Andrew said: @F10-65 Post from 1st July last year. More build up in the last 11 months than the previous similar time frame. Although it has been much wetter I reckon and I do park nowadays nearer more trees so more chance for muck to build up. So are you going to look at yours again then? 🤣 Will do at the weekend 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 4 Author Share Posted June 4 Got some nice beading this morning following the weekends efforts. Also ordered a replacement drivers wing mirror glass as mine is currently on a shoogly peg and ready to drop off. £15 from Amazon. 3 Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 5 Author Share Posted June 5 Mr Amazon delivered my replacement wing mirror glass today. 1 Quote Link to comment Share on other sites More sharing options...
F10-65 Posted June 6 Share Posted June 6 The postman delivered my 20 new wheel bolts this morning… Ready to fit this weekend 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 6 Author Share Posted June 6 What make are they then @F10-65? Quote Link to comment Share on other sites More sharing options...
F10-65 Posted June 6 Share Posted June 6 13 minutes ago, Andrew said: What make are they then @F10-65? No clue on brand but are identical to genuine on at the mo. Want a link? Quote Link to comment Share on other sites More sharing options...
F10-65 Posted June 6 Share Posted June 6 11 hours ago, F10-65 said: The postman delivered my 20 new wheel bolts this morning… Ready to fit this weekend I forgot, I’ve got tomorrow off from work. So fit new nuts, firmware on apple CarPlay unit and just changed rear brakes but service counter won’t reset. Do you think I’ve put the sensor on backwards? Quote Link to comment Share on other sites More sharing options...
Dimsum Posted June 6 Share Posted June 6 Full service with the main dealer who kindly relieved me of £608. My local specialist quoted me a bit cheaper (£450 ish) but it’s had main dealer servicing all its life and the OCD side of me wanted to keep that going. Quote Link to comment Share on other sites More sharing options...
Andrew Posted June 6 Author Share Posted June 6 2 hours ago, F10-65 said: just changed rear brakes but service counter won’t reset. Do you think I’ve put the sensor on backwards? Assuming New sensor and required service warning was at least yellow or red. If green reset not possible. Handbrake needs to be off before reset procedure will work. Follow this post 1 Quote Link to comment Share on other sites More sharing options...
