Sharkfan Posted March 13 Author Share Posted March 13 (edited) Already sorted the mph thing a little with a transfer I had made up by the original Pukar decals man... In terms of reading the display a little more easily I would probably put a tiny amount of red enamel paint on the 50kmh (30mph), 80kmh (50mph) and somewhere between the 110 and 120kph (69 to 77mph) markers. I got the instructions today - it's basically take out one 51.1ohm (or thereabouts) resistor on the back of the speedo - wire in a a remote 0-100ohm variable trimpot resisitor and mount it remotely (hanging down under the dash?!), test and adjust against a GPS speedo on a flat road and then either leave the trimpot tucked out of the way or remove the trimpot and solder in some resistors to the value of the trimpot. Edited March 19 by Sharkfan 2 Quote Link to comment Share on other sites More sharing options...
Ordnator 2 Posted March 14 Share Posted March 14 On 13/03/2024 at 17:55, Sharkfan said: Already sorted the mph thing a little with a transfer I had made up by the original Pukar decals man... In terms of reading the display a little more easily I would probably put a tiny amount of red enamel paint on the 50kmh (30mph), 80kmh (50mph) and somewhere between the 110 and 120kph (69 to 77mph) markers. I got the instructions today - it's basically take out one 51.1ohm (or thereabouts) resistor on the back of the speedo - wire in a a remote 0-100ohm variable trimpot resisitor and mount it remotely (hanging down under the dash?!), test and adjust against a GPS speedo on a flat road and then either leave the trimpot tucked out of the way or remove the trimpot and solder in some resistors to the value of the trimpot. Sounds a lot like a Maritime "set-to-work" and "Harbour Acceptance Trial" (HAT) process to me. But then most things do That is a sound engineering approach to the problem Best regards, Mick Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted March 15 Share Posted March 15 Assume you have this SF? https://www.ebay.co.uk/itm/354915779585?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20211130130302%26meid%3De1640373ff864e5a9b6b853613dc0c71%26pid%3D101468%26rk%3D1%26rkt%3D4%26sd%3D166551688241%26itm%3D354915779585%26pmt%3D1%26noa%3D0%26pg%3D3650466%26algv%3DSimplAMLv5PairwiseWeb%26brand%3DAlpina&_trksid=p3650466.c101468.m3476&itmprp=cksum%3A354915779585e1640373ff864e5a9b6b853613dc0c71|enc%3AAQAJAAAA8KWQuUK9rdmHpme4uO0BObpfDfF2Hh6aALT%2BkIwpRrc4GgYFRhRmpCLMKdY9TVd9mGv0WnJCGTwOOrq9239o4GqjLSAqRrXmjyV3GluSIyJZ7UIYGtfT1lmlfCGhf6VfbULFomAGBlUIrlfIKSNklRQJA%2BnbtE4Wnow0a0iSGagDHgbZCv%2B%2BHhN5KYqreQwODyrselLmyJlVjJZAo14FQuJBDx2xnDT1okNwO5G0VR8XXwGxjREl7kt3tEkxRm3pLJ1QowXTuAK2H8w%2BYybWU0E3a3j57XlL3XT%2BUtF7Dae4CNh2MSywK5exjOSxl95l0g%3D%3D|ampid%3APL_CLK|clp%3A3650466&itmmeta=01HS18XEYVRHAYZP30MR6WF8XE Quote Link to comment Share on other sites More sharing options...
Sharkfan Posted March 15 Author Share Posted March 15 Yep... https://www.forum5.co.uk/topic/1255-calling-sharkfan-otto-e34-alpina-b10-touring-model/#comment-4813 ...although it's badged as B10 4.0 of which Alpina made only 4 Tourings, but MCG have now released a 1:18 B10 4.6 Touring in green... https://www.carmodel.com/mcg/mcg18331/1-18/bmw/5-series-b10-4-6-alpina-touring-e34-sw-station-wagon-1989/175937 I need to photograph my 1:18 M635CSi, B10 and B12 just like this... 1 Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted March 15 Share Posted March 15 Aah yes i remember now - MCG models are OK, i have an Mk1 astra GTE (well opel kadette) its not bad, the other one that impressed me was Laudo Racing Models - got a nice Alfa 33 model near identical to my car! Quote Link to comment Share on other sites More sharing options...
Sharkfan Posted March 26 Author Share Posted March 26 Next silly thing that I’m not quite sure about. E34 M5 saloons had a black plastic insert between the rear lights underneath the number plate - BMW ///M couldn’t be arsed to make one for the M5 Touring so they got a flat black sticker instead - luckily someone invented 3D printing and sometimes Etsy got busy and made a plastic bit for E34 Tourings. 2 Quote Link to comment Share on other sites More sharing options...
Sharkfan Posted May 25 Author Share Posted May 25 Early morning snapping… 1 Quote Link to comment Share on other sites More sharing options...
Ordnator 2 Posted June 8 Share Posted June 8 On 25/05/2024 at 02:31, Sharkfan said: Early morning snapping… Both built to a standard rather than a budget... Best regards, Mick Quote Link to comment Share on other sites More sharing options...
