Andrew Posted August 22, 2022 Share Posted August 22, 2022 they can be stopped dead in their tracks by a Creme egg. https://www.bbc.co.uk/news/uk-scotland-north-east-orkney-shetland-44561039 Oh how hard did I laugh at that. Pity, such a waste of a good Creme egg🤣 Quote Link to comment Share on other sites More sharing options...
Caesar Posted August 22, 2022 Share Posted August 22, 2022 Well that looks like a very complicated repair! Was that a Shell service station? Â 1 Quote Link to comment Share on other sites More sharing options...
Kopfjaeger Posted October 4, 2022 Share Posted October 4, 2022 It should be a simple repair if engineered correctly. Cover off to expose connector and clean and dry off terminals, etc. I doubt the connector would need replacing, so time intensive, most likely. If its more complicated than that, then it's a poor design, as this is a high use part that is likely to wear out over time, so good engineering practice would dictate that this part should be readily serviced or capable of repair. I doubt the designers considered abuse by creme eggs though...... If we are to have a robust electric vehicle charging infrastructure, then the designers need to think outside the box and consider TCO and not just Capex.... You wouldn't have the same problem with a liquid fuel delivery terminal. Quote Link to comment Share on other sites More sharing options...
BobA Posted October 6, 2022 Share Posted October 6, 2022 On 04/10/2022 at 22:47, Kopfjaeger said: You wouldn't have the same problem with a liquid fuel delivery terminal. Maybe not the SAME problem, but I wouldn’t fancy a squashed crème egg ending up in my tank when someone squashed one up the nozzle! 😉 Quote Link to comment Share on other sites More sharing options...
Kopfjaeger Posted October 6, 2022 Share Posted October 6, 2022 Good point......I never thought about that. Luckily, so far, the creme-egg brigade don't appear to target E5 fuel pumps. Quote Link to comment Share on other sites More sharing options...
Andrew Posted October 7, 2022 Author Share Posted October 7, 2022 On 06/10/2022 at 10:08, BobA said: Maybe not the SAME problem, but I wouldn’t fancy a squashed crème egg ending up in my tank when someone squashed one up the nozzle! 😉 Sugar in your tank will help it run sweet......... Quote Link to comment Share on other sites More sharing options...
norseman Posted October 24, 2022 Share Posted October 24, 2022 On 07/10/2022 at 10:29, Andrew said: Sugar in your tank will help it run sweet......... Amusing, but technically incorrect 🙄 Quote Link to comment Share on other sites More sharing options...
