Calypso-E34 Posted August 17, 2022 Share Posted August 17, 2022 I have a 2016 520d Sport, but this issue might be relevant on any BMW really. Occasionally when I start the car, I get a gong and display, suggesting that the car is overdue an inspection or an oil change by 400 odd miles, when no service is due for around 7000 miles. Next time I start up, everything will be back to normal. This happened now and then on my 2010 525d too. I have chosen to ignore it, but I am curious about what might be causing this. Has anyone else had this issue? Quote Link to comment Share on other sites More sharing options...
Andrew Posted August 17, 2022 Share Posted August 17, 2022 Burn it! 🔥 Just testing a new feature, The stock reply function. 👍 @VPCAPTAIN, may have also had similar on his 2015 version. It's fine one day then the next its different from the previous. Probably be cured by a software update I would think. 1 Quote Link to comment Share on other sites More sharing options...
Calypso-E34 Posted August 18, 2022 Author Share Posted August 18, 2022 13 hours ago, Andrew said: Burn it! 🔥 It won't burn properly - it's a diesel!! 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted August 18, 2022 Share Posted August 18, 2022 Once something is hot enough, it will burn. 🤣 Quote Link to comment Share on other sites More sharing options...
