Andrew Posted August 17, 2022 Share Posted August 17, 2022 To edit a post you have made, click on the three dots at the top of your post and then click on Edit in the menu that now appears This opens up the post to allow you to make any changes. Once you have finished editing... Fill in the box that explains the "Reason for edit" and then click the blue button, Edit Topic. Job done Your screen may vary slightly as I can see additional functions as an Admin 1 Quote Link to comment Share on other sites More sharing options...
