Wagse Posted September 13, 2022 Share Posted September 13, 2022 Hi everyone. my brake service light as come etc. But there’s still plenty of life in the front brakes, I’ve tried to reset this by going into the hidden menu but after going through the process of resetting it comes up with unable to reset. Is the any other way to reset it, or have I got to either replace pads or change the sensor. Quote Link to comment Share on other sites More sharing options...
Stacker Posted September 13, 2022 Share Posted September 13, 2022 What year is your car ? This is likely to change what you may need to do. I have a G31 and I did a few hundred past the warning. BMW technician told me that the inner pads which couldn't be seen were actually worn more than the outer, so I'm glad I didn't go too much over! Quote Link to comment Share on other sites More sharing options...
Andrew Posted September 13, 2022 Share Posted September 13, 2022 9 hours ago, Wagse said: Hi everyone. my brake service light as come etc. But there’s still plenty of life in the front brakes, I’ve tried to reset this by going into the hidden menu but after going through the process of resetting it comes up with unable to reset. Is the any other way to reset it, or have I got to either replace pads or change the sensor. If you tell us what type of 520d it is we can help. If its an E60 or newer it needs a new pad wear sensor If it’s an F generation.... see below Quote Link to comment Share on other sites More sharing options...
Wagse Posted September 22, 2022 Author Share Posted September 22, 2022 So I thought I would do a update on brake warning light, so when I had a proper look there was plenty of life in pads both in and outer pads, but the sensor for some reason and ripped and broke away from pads. I then decided to replace pads and disc's re paint Calliper's etc looks nice now just need to finish the bedding in process Quote Link to comment Share on other sites More sharing options...
