Wiper washer tank loosing water!
Well, ‘surprisingly’ my car has another issue…it is losing water from the wiper washer tank…i am finding water under the car next to the front left wheel.
is this a common failure?  Cracks?  Typical bmw biodegradable plastic?
Is it accessible from the under tray?
Thanks
Thanks
I've seen the pipe come loose on other cars, but I have not experienced it. The only problem I suffered on my car was my fault; I used cheap screen wash which forms a gel and blocks everything.
As @Gonzo said, you need to pull back the wheel arch liner on the passenger side to gain access.
Edited by Changy
