Dpf error 245700
I had an engine light come on today. When I plugged Carly in it came up with error number 245700. I checked the back pressure and it is not in MB it's in HPA so I'm not sure what the reading should be. I did clear codes and take it on a motorway run and the soot went down from 30g to 2g.
hPa is hectopascal
1 hPa = 1mb one millibar
As a Civil Engineer, I need to think in terms of kN/m^2 for pressures and N/mm^2 for stress. Hate working in Pascals.... weird continental units.....🤪
6 minutes ago, Andrew said:
hPa is hectopascal
Does that mean the back pressure is over 1000mb  isn't that high ? If so what could be the cause of it ?
I thought max limit is 300mb
High back pressure warning indicates constriction within the dpf.
Assuming it's not a faulty/failing pressure sensor then the options are clogged dpf itself, or of the bypass tube. The bypass tube is where the pressure sensor gets its comparison from.
As you've done a run and the soot mass has dropped (dramatically) I'd guess it should now clear the fault. But if it built up to that extent it may indicate regeneration isn't taking place.
I called a dpf guy I know he said given the mileage I have done,it could be ash build up (255k miles) I haven't had the dpf cleaned or anything. He said the car is regenerating but the ash is most likely causing the high pressure and dpf taken off and cleaned in their cabinet machine. He will check on Tuesday. So will let you know.
