Abdul Posted July 31 Share Posted July 31 hi guys just purchased a F10 520D. I have the B47 engine, just wondering if the N47 rad pack will fit? cheers Quote Link to comment Share on other sites More sharing options...
Shakeel.j Posted July 31 Share Posted July 31 Yes it will fit, if it's accident damaged it might be best to take it apart first there is loads of plastic brackets Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 31 Share Posted July 31 Why fit a radiator from an inferior engine? New radiators are not very expensive in the run of things. Get the proper one. Quote Link to comment Share on other sites More sharing options...
Matthew Posted August 1 Share Posted August 1 16 hours ago, Abdul said: hi guys just purchased a F10 520D. I have the B47 engine, just wondering if the N47 rad pack will fit? cheers You can use Realoem.com to check parts. I've take a look for you and the Pre (N47) and Post LCI (B47) use the same radiator and radiator carrier. 1 Quote Link to comment Share on other sites More sharing options...
