999mch Posted July 18 Share Posted July 18 I need to get a cable through the front bulkhead to wire in my front camera. I have looked at the main wiring loom and that doesn't seem to have any slack in it for an extra cable. Has anybody managed to get another cable through the bulkhead. It is on an F11 but probably very similar on many BMW's. Any advice much appreciated Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 18 Share Posted July 18 Take a piggy back fuse holder from F54 in the passenger footwell fuse box. Or run a fused wire from the battery in the boot following the existing looms under the side trims. Quote Link to comment Share on other sites More sharing options...
Matthew Posted July 18 Share Posted July 18 To get the camera data cable through to the cabin, remove the blower motor and its housing and you can then get the cable through the existing large wiring harness grommet into the near side passenger footwell. I’ve done this a couple of times on the F10/11 when replacing the side view camera and cable. Quote Link to comment Share on other sites More sharing options...
999mch Posted July 19 Author Share Posted July 19 8 hours ago, Matthew said: To get the camera data cable through to the cabin, remove the blower motor and its housing and you can then get the cable through the existing large wiring harness grommet into the near side passenger footwell. I’ve done this a couple of times on the F10/11 when replacing the side view camera and cable Thanks I will give that a try, annoyingly I have put the cable to the driver side at the moment but will reroute to the passenger side. It should be easier as I have already put the box of tricks in the glove box after I couldn't get it behind the headunit. Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 19 Share Posted July 19 Apologies, when you said front camera I took that as a front screen fitted dash cam. But I’m guessing that isn’t the case where’s the camera mounted? There are wires that pass thru the bulkhead under the brake master cylinder that link the drivers side cockpit to the engine fuse box which is adjacent to the brake master cylinder. Depending on the thickness of the cable you are looking to push thru you might be able to squeeze a cable thru an existing cable grommet alongside existing wiring. I’ve done that on older cars routing power from an engine bay mounted battery to towbar wiring in the boot. I used a straightened out wire coat hanger to push cable thru the grommets with other wires. Quote Link to comment Share on other sites More sharing options...
Kopfjaeger Posted July 19 Share Posted July 19 There is a 20mm grommet in the drivers side, on my F07 ar least. The F10/11 should be similar? I used mine for the front fog lamp wiring. You will need a grommet to maintain waterproofing though. Quote Link to comment Share on other sites More sharing options...
Matthew Posted July 20 Share Posted July 20 On 19/07/2024 at 07:55, 999mch said: Thanks I will give that a try, annoyingly I have put the cable to the driver side at the moment but will reroute to the passenger side. It should be easier as I have already put the box of tricks in the glove box after I couldn't get it behind the headunit. This is your best option to go through the same route as the side view cameras would have done which, on RHD cars, is as I mention, through the large clump of wires routed next to the blower housing. 1 Quote Link to comment Share on other sites More sharing options...
