vRS_Billy Posted June 5 Share Posted June 5 (edited) hello, could I get prices on the following parts please. W383AEP Cap 5121 816 3 829 £ Nut 2231 767 0 944 x3 £ O ring 3241 112 8 333 £ Nut 6450 912 3 157 x2 £ Mount 6412 136 5 602 x2 £ PAS Pulley 1128 224 8 214 £ A/C Pulley 1128 140 7 520 £ Pipe 3432 675 5 306 £ Pipe 3432 675 5 308 £ Clip 3434 116 3 565 £ Pipe 3432 675 5 316 £ Pipe 3432 675 5 312 £ Washer 3430 116 3 613 x2 £ Washer 3713 111 4 028 x2 £ Grommet 3430 686 5 954 x2 £ Bracket 3432 685 5 500 x4 £ Clamp 3432 116 2 455 x4 £ Bracket 3430 116 2 364 x4 £ Brake 5121 819 3 447 x2 £ Bolt 5121 197 3 382 x4 £ Pin 5121 814 1 116 x2 £ Cover 5121 817 1 502 x2 £ Gasket 5121 817 1 503 x2 £ Shifter and Gaiter 2511 228 4 205 £ Handbrake lever 3441 116 3 962 £ Centre Tie Rod 3221 109 6 060 £ Cheers Edited June 11 by vRS_Billy Quote Link to comment Share on other sites More sharing options...
Cotswoldbmwmini Posted June 6 Share Posted June 6 Hi, Please can you check the second part number as it isn't recognised and hasn't been superseeded? Also if you could let us know your email address so we can forward you the itemised quotation. Many thanks Joe Quote Link to comment Share on other sites More sharing options...
vRS_Billy Posted June 6 Author Share Posted June 6 27 minutes ago, Cotswoldbmwmini said: Hi, Please can you check the second part number as it isn't recognised and hasn't been superseeded? Also if you could let us know your email address so we can forward you the itemised quotation. Many thanks Joe Hi Joe, It's the nuts for the top cover of the battery box. They hold down the plastic cover over the battery in the M5 Pmd email address too Cheers Quote Link to comment Share on other sites More sharing options...
vRS_Billy Posted June 7 Author Share Posted June 7 Did you get my Pm with email mate? Quote Link to comment Share on other sites More sharing options...
Cotswoldbmwmini Posted June 10 Share Posted June 10 Hi, Email sent with quote attached. Many thanks Joe 1 Quote Link to comment Share on other sites More sharing options...
