F10 Blower Motor Malfunction
Posted (edited)
Hi,
I'm having a malfunction on my blower motor.
When the engine is running, it seems to be stuck at a constant rotation, regardless of any setting i set the fan to. Air is flowing into the cabin only through the windshield vents.
The a/c is not working as well.
After i switch off the ignition, the motor keeps running.
I had to remove the dedicated fuse (11) to prevent battery drain.
When i ran an obd scanner, it threw the codes attached.
Has anyone ever faced this issue?
Cheers,
Edited by MacPedro
On 11/05/2024 at 16:51, MacPedro said:
Hi,
Cheers,
For the blower motor, you probably need to change the Blower regulator - RealOEM.com - Part Search. You may find that once changed the other errors go away too.
Posted (edited)
Thanks @Matthew,
I'm abroad for a couple of weeks. Will get on to this when i get back and report progress then. Hopefully, that'll fix it!
Edited by MacPedro
  • 2 weeks later...
