MacPedro Posted May 11 Share Posted May 11 (edited) Hi, I'm having a malfunction on my blower motor. When the engine is running, it seems to be stuck at a constant rotation, regardless of any setting i set the fan to. Air is flowing into the cabin only through the windshield vents. The a/c is not working as well. After i switch off the ignition, the motor keeps running. I had to remove the dedicated fuse (11) to prevent battery drain. When i ran an obd scanner, it threw the codes attached. Has anyone ever faced this issue? Cheers, Edited May 11 by MacPedro Quote Link to comment Share on other sites More sharing options...
Matthew Posted May 13 Share Posted May 13 On 11/05/2024 at 16:51, MacPedro said: Hi, I'm having a malfunction on my blower motor. When the engine is running, it seems to be stuck at a constant rotation, regardless of any setting i set the fan to. Air is flowing into the cabin only through the windshield vents. The a/c is not working as well. After i switch off the ignition, the motor keeps running. I had to remove the dedicated fuse (11) to prevent battery drain. When i ran an obd scanner, it threw the codes attached. Has anyone ever faced this issue? Cheers, For the blower motor, you probably need to change the Blower regulator - RealOEM.com - Part Search. You may find that once changed the other errors go away too. Quote Link to comment Share on other sites More sharing options...
MacPedro Posted May 14 Author Share Posted May 14 (edited) On 13/05/2024 at 07:07, Matthew said: For the blower motor, you probably need to change the Blower regulator - RealOEM.com - Part Search. You may find that once changed the other errors go away too. Thanks @Matthew, I'm abroad for a couple of weeks. Will get on to this when i get back and report progress then. Hopefully, that'll fix it! Edited May 14 by MacPedro Quote Link to comment Share on other sites More sharing options...
MacPedro Posted May 28 Author Share Posted May 28 Just reporting back on this issue. Replaced the blower regulator and issue was fixed, thanks again @Matthew 1 Quote Link to comment Share on other sites More sharing options...
