0011718 Posted March 3 Share Posted March 3 Hi guys, one of my windscreen washer jets has started to block up on the drivers side. It still squirts onto the windscreen but only just. Others work fine. Any advice on how to unblock the jet? Quote Link to comment Share on other sites More sharing options...
Matthew Posted March 4 Share Posted March 4 10 hours ago, 0011718 said: Hi guys, one of my windscreen washer jets has started to block up on the drivers side. It still squirts onto the windscreen but only just. Others work fine. Any advice on how to unblock the jet? It is usually the filter on the pump on the washer fluid reservoir that blocks with organic crud but as you have just one jet not working, other than replacing them all (they come as a unit) this is probably your only other option: Windscreen Washer Nozzle Adjustment Tool, Windshield Washer Jet Cleaning Tool, Car Windscreen Jet Nozzle Washer Cleaner Needle : Amazon.co.uk: Automotive. I used it on my previous non-BMW so no idea if it is suitable for your. Quote Link to comment Share on other sites More sharing options...
0011718 Posted March 7 Author Share Posted March 7 Thanks Matthew Quote Link to comment Share on other sites More sharing options...
