Apologies, my suspension again
So the rear end went on the motorway on the way home from work the other night.  Warning on dashboard said chassis ok to continue journey.
garage have reset and the suspension stays up, then put it on the road and it collapses, anyone familiar with this?
also has anyone converted the rear suspension to shocks? Dont really want to do that but I’m cheesed off having only had the car 5 months and this is my 2nd issue.
thanks
Is it sinking on both sides? In my experience if its the bags then its one side or the other - if its both sides and its pumping up then i would be looking at level sensors and the like.
Did you find the source of the leak out of interest?
3 hours ago, duncan-uk said:
Correct but has a cover that could trap water I guess.
definitely they do get wet and they have a s
desiccant that can be dried out.
Sorry what do you mean by this?
I meant on mine the compressor is mounted on a cradle under the floor and has a plastic cover to protect it - i guess that could fill with water.
As 0011718 there is a dryer in the compressor - i've seen videos of these flooded which stops the compressor.
Mine was bone dry but the relay in the boot was flooded.
On 17/02/2024 at 20:55, 0011718 said:
The dessicant is inside the compressor
This is to dry the air after it’s been compressed. Not to stop moisture damaging the unit as such.
Air has moisture in it and when compressed water droplets form as water can’t be compressed and if it wasn’t for the desiccant to absorb the water, there is a risk of moisture then getting into the air lines and bags which will destroy them.
It’s why workshops have water traps in their compressed air lines. They don’t want water getting into air tools and rusting them from the inside out.
