Humour Posted March 14 Share Posted March 14 2 hours ago, Ray112 said: I tried fair few LEDs in dipped and high beam, none of them were impressive in longer distance. Took my car to MOT test with my hid kit installed (all ballasts and wiring is hidden completely underneath headlights) and it passed without any issues. And no, I didn't know anyone in that garage either, so it wasn't friendly mot tester. They hardly pull you up on this type of thing Kate, just if the lights are out of alignment or not. I've had modded headlights on all but 1 motor in my time and been to 20+ different MOT garages and never been pulled on that even with Ballasts showing. Most have no way of knowing if it was a factory option or not, so they don't bother. Quote Link to comment Share on other sites More sharing options...
Ray112 Posted March 14 Share Posted March 14 33 minutes ago, Humour said: They hardly pull you up on this type of thing Kate, just if the lights are out of alignment or not. I've had modded headlights on all but 1 motor in my time and been to 20+ different MOT garages and never been pulled on that even with Ballasts showing. Most have no way of knowing if it was a factory option or not, so they don't bother. True, if beam pattern is clear and correct, bulb colour isn't something stupidly blue, and they are fitted in projector headlights, I can't see anything wrong with hid/led bulbs. Plus I went another step ahead and retrofitted headlight washers, so it all looks pretty much original. Quote Link to comment Share on other sites More sharing options...
