Sgc22 Posted December 24, 2023 Share Posted December 24, 2023 Hi, was out and just went back to the car and the back end is sitting on top of the wheels. waiting on the aa picking me and towing me home, no idea where to take it at this time of the year near Cumbernauld just outside Glasgow. Quote Link to comment Share on other sites More sharing options...
Matthew Posted December 24, 2023 Share Posted December 24, 2023 1 hour ago, Sgc22 said: Hi, was out and just went back to the car and the back end is sitting on top of the wheels. waiting on the aa picking me and towing me home, no idea where to take it at this time of the year near Cumbernauld just outside Glasgow. Do a search here, very common for failures of the rear suspension airbags, solenoid and/or compressor. 1 Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 24, 2023 Share Posted December 24, 2023 2 hours ago, Sgc22 said: no idea where to take it at this time of the year near Cumbernauld just outside Glasgow. Plenty of BMW specialists in Glasgow if you search. Can only recommend BMW dealer Harry Fairbairn which is Arnold Clark now, in Giffnock (Southside of Glasgow) Do not and I repeat do not go to any branch of Douglas Park BMW. The saggy F11 backend is a common complaint and this forum has its fair share of victims of that complaint but also fixes. Can you hear the compressor run? Check its fuses and relay which can get water damaged and thus cut out and gravity takes over. It’s in the battery boot well. 1 Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted December 25, 2023 Share Posted December 25, 2023 Have a look at relay in boot well, just had similar with car suddenly on its arse but i had no sign of compressor running, was the relay in the boot well - seems i have water ingress... Quote Link to comment Share on other sites More sharing options...
Sgc22 Posted January 4 Author Share Posted January 4 So an update, car was lifted taken to lawsons autotech in larbert and the guy who moved it on his trailer called me to say that he delivered the car and as he unloaded it the suspension lifted of its own accord. awaiting diagnosis tomorrow now. Quote Link to comment Share on other sites More sharing options...
HandyAndy Posted January 5 Share Posted January 5 Dodgy front/rear level sensor perchance?🙄 Quote Link to comment Share on other sites More sharing options...
Sgc22 Posted January 6 Author Share Posted January 6 The garage can’t find a fault, they are leaving it on the ramp over the weekend Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted January 6 Share Posted January 6 Have a look in well under boot floor - see if relay is damp. Quote Link to comment Share on other sites More sharing options...
0011718 Posted January 6 Share Posted January 6 This happened to mine once and never did get to the nottom of it. However I did wonder if it was because I had been out to the car to move it a small distance, and if the compressor was working to raise the rear suspension because it had dropped overnight AND I then switched the car off while the compressor was still woking would this leave a valve open causing it then to slowly drop? Quote Link to comment Share on other sites More sharing options...
Sgc22 Posted January 8 Author Share Posted January 8 So it’s both real level sensor link rods which have seized. there has been water in the boot previously but it’s dry and the Relay is fine and the compressor is also good. cost is £193 plus initial diagnostic cost. Quote Link to comment Share on other sites More sharing options...
Andrew Posted January 8 Share Posted January 8 8 hours ago, Sgc22 said: there has been water in the boot previously but it’s dry If water has got in, it's likely to find it's way back it. It's a bit pesky in that department. Make sure it stays out. But thanks for coming back on to share the solution. @VPCAPTAIN, worth checking on your F11. 1 Quote Link to comment Share on other sites More sharing options...
therealmc Posted January 24 Share Posted January 24 On 08/01/2024 at 11:38, Sgc22 said: So it’s both real level sensor link rods which have seized. there has been water in the boot previously but it’s dry and the Relay is fine and the compressor is also good. cost is £193 plus initial diagnostic cost. I’m wondering if I have a similar problem. Replaced the compressor not just the solenoids and some times the car stays up for days and others it drops. It’s the same both sides and doesn’t seem like an airbag leak. Is replacement of these parts a diy job - they’re cheap to buy? Quote Link to comment Share on other sites More sharing options...
Sgc22 Posted January 28 Author Share Posted January 28 On 24/01/2024 at 20:35, therealmc said: I’m wondering if I have a similar problem. Replaced the compressor not just the solenoids and some times the car stays up for days and others it drops. It’s the same both sides and doesn’t seem like an airbag leak. Is replacement of these parts a diy job - they’re cheap to buy? I have no mechanical skills whatsoever so no idea if it’s diy but the parts weren’t expensive Quote Link to comment Share on other sites More sharing options...
Sgc22 Posted February 14 Author Share Posted February 14 And it’s gone again on the way home from work, suspension both sides with warning on dash saying chassis, safe to continue, so I’ve limped it home. This car is cursed Quote Link to comment Share on other sites More sharing options...
