Skynet5 Posted December 2, 2023 Share Posted December 2, 2023 Had a fun drive home. No water coming out of jets. So when I pull the stalk the wipers go. But I hear no sound of a pump. Thought it might be frozen. When my lights came on the headlight washers worked, and the distinctive sound of a pump is heard. But no sound of a pump at all for the windscreen jets. any pointers on what to check? I guess as the car is 7 years old it could easily be a pump failure or a fuse gone. tips and links appreciated and I’ll try and sort It myself rather than have to take it to a dealer. Quote Link to comment Share on other sites More sharing options...
Skynet5 Posted December 2, 2023 Author Share Posted December 2, 2023 (edited) So I went to check the fuse box. Noticed the lead to my dash cam was off at the camera end. I guess the mechanic disconnected that. Plugged it in and then checked the washer and it worked. obviously the dash cam being unplugged didn’t make me think it would disable the washer 🙂 so I looked at the fuse box and found I had piggy backed off the lighter anyway. so no clue. But now it all seems to be working without doing anything. Edited December 2, 2023 by Skynet5 Quote Link to comment Share on other sites More sharing options...
Steve84N Posted December 2, 2023 Share Posted December 2, 2023 I've had a few instances where my windscreen jets didn't work and then they did the next time. Reading fault codes it showed a blockage, so perhaps there's some gunk somewhere that trips an over pressure warning sometimes such that they don't work. I've nearly run out of fluid and I'm going to switch to the BMW stuff. If it happens again I may have to clean the system. Quote Link to comment Share on other sites More sharing options...
Skynet5 Posted December 3, 2023 Author Share Posted December 3, 2023 (edited) 13 hours ago, Steve84N said: I've had a few instances where my windscreen jets didn't work and then they did the next time. Reading fault codes it showed a blockage, so perhaps there's some gunk somewhere that trips an over pressure warning sometimes such that they don't work. I've nearly run out of fluid and I'm going to switch to the BMW stuff. If it happens again I may have to clean the system. That’s good to know thanks. I always use bmw screen wash just on the safe side as mixing leads to problems apparently. I've got an odb reader but not used it for a while. what’s the best free app to use these days? Edited December 3, 2023 by Skynet5 Quote Link to comment Share on other sites More sharing options...
