Creaking drivers seat
Matt
Likely the plastic adjustment trim, same issue exists since the E46 it seems. Grab the trim, wiggle it and see if it creaks.
Solution is to take it apart & apply Krytox (it's like magic) to all the contact points. Got rid of my terminal creaks completely. Even used it in my center console to completely silence it
  • 1 month later...
23 hours ago, Matt said:
4aceman, which Krytox product did you use?
I got GPL 105 from a mechanical keyboard website. Got 10g and used perhaps 1/3 of it covering all the door/boot seals and creaky interior bits.
