Matt Posted November 17, 2023 Share Posted November 17, 2023 Starting to really get on my wick, any movement in the seat or driving over bumps and its creaking and squeaking. Anyone else had this and know of a fix without replacing the entire seat and base? Quote Link to comment Share on other sites More sharing options...
Steve84N Posted November 17, 2023 Share Posted November 17, 2023 You could check the four bolts in the floor are still tight as something easy to try. Quote Link to comment Share on other sites More sharing options...
Shakeel.j Posted November 18, 2023 Share Posted November 18, 2023 Have you checked if it's the plastic trim around the adjustment buttons. Quote Link to comment Share on other sites More sharing options...
4aceman Posted November 20, 2023 Share Posted November 20, 2023 Likely the plastic adjustment trim, same issue exists since the E46 it seems. Grab the trim, wiggle it and see if it creaks. Solution is to take it apart & apply Krytox (it's like magic) to all the contact points. Got rid of my terminal creaks completely. Even used it in my center console to completely silence it Quote Link to comment Share on other sites More sharing options...
Matt Posted January 10 Author Share Posted January 10 4aceman, which Krytox product did you use? Quote Link to comment Share on other sites More sharing options...
4aceman Posted January 11 Share Posted January 11 23 hours ago, Matt said: 4aceman, which Krytox product did you use? I got GPL 105 from a mechanical keyboard website. Got 10g and used perhaps 1/3 of it covering all the door/boot seals and creaky interior bits. 1 Quote Link to comment Share on other sites More sharing options...
