E39mad Posted November 1, 2023 Share Posted November 1, 2023 Is there any way of connecting your ipod classic through the USB C connection? No auxiliary jack like in the old F11 and looking through other forums it appears that a USB C direct to ipod does not appear to work. Has anyone found a solution to this? Quote Link to comment Share on other sites More sharing options...
Sharkfan Posted November 1, 2023 Share Posted November 1, 2023 How 'classic' is the iPod? Up to Gen 4 were 12v charging and then 5v charging after that. You used to be able to get FM transmitters that plugged straight into the wide 'classic' iPod/iPhone port so that might be your only way unless you can find a wired Aux-in on a G3* car. I have 12v Classic Generation 4 iPods in all my cars - most connected to a headunit Aux in (E34 & E24) and some connected through tape head connectors (E39 & E38). Quote Link to comment Share on other sites More sharing options...
E39mad Posted November 1, 2023 Author Share Posted November 1, 2023 It's a 2008 model so likely to be 12v. Quote Link to comment Share on other sites More sharing options...
Matthew Posted November 2, 2023 Share Posted November 2, 2023 Just get yourself a USB-C USB stick and export your iTunes library to it with the playlists. It is accessed much quicker by the system and you can get tiny discrete ones. I stopped using the iPod in the cars years ago and have one each of these plugged in to both cars and very happy with the results. 1 Quote Link to comment Share on other sites More sharing options...
E39mad Posted November 2, 2023 Author Share Posted November 2, 2023 3 hours ago, Matthew said: Just get yourself a USB-C USB stick and export your iTunes library to it with the playlists. It is accessed much quicker by the system and you can get tiny discrete ones. I stopped using the iPod in the cars years ago and have one each of these plugged in to both cars and very happy with the results. Thanks - don't think we have the PC with iTunes on it anymore - might have to find a way of downloading them from ipod to PC then export to a stick. Quote Link to comment Share on other sites More sharing options...
