F10 535i N55 DIY - Oil filter housing gasket and oil cooler gasket replacement.
Andrew
  • 1 month later...
Not sure if @cube will post back here but on Pistonheads there's a post saying they went ahead with a new crate engine from BMW and reconditioned turbo, fitted by CPC Engineering in Amersham following my tip.
@duncan-uk you should be on commission for N55 engines! 🤣
  • 3 months later...
Hi Andrew long time no see/speak still rocking the 535i hope your well ...
Is this the same for n57 yes am back in a bmw just a f15 this time
Edited by marko530d
Good to hear from you.
I'm not sure about the diesel oil coolers, the gaskets I changed are very similar to those on all the petrol four and other 6 pots.
