Front brake disc replacement brake disc type
MikeNoble
Hi all, looking for some advice on replacement front brake discs for my E61.
I got replacement Brake Disc Blue Print ADB114362 Febi Bilston for my car which according to Amazon fits my car but they look different to the ones I have on. My car had done 190K when I bought it so the ones that are on will likely not be the originals.
These new ones have a step in the hub but the ones on the car the hub is the same diameter all the way, also it looks like these replacement ones are a slightly smaller disc diameter at 310mm.
My car reg is PE10ZNR can anyone confirm what diameter the discs should be and are the Blue Print ones I have correct for the car?
Appreciate your help guys as this job has been stressing me out for weeks.
