Cadwell Parker Posted July 8, 2023 Share Posted July 8, 2023 1 pair variable damping rear shock absorbers from a BMW 5 Series touring F11. Part nos 37.12 - 6796985 + 37.12 - 6796986 These are in good working order with no leaks or damage and have covered 80000 miles so plenty of life left in them. Selling as a matched pair. Some surface corrosion but nothing major. Slight corrosion on the tops of the damper rods but doesn't affect operation. Just to point out in case you're not aware these will require coding to the car. £550 inc Royal Mail 48hr postage Happy to upload more photos if needed. Just ask 😀 Quote Link to comment Share on other sites More sharing options...
Bogdan Posted August 28 Share Posted August 28 On 08/07/2023 at 15:37, Cadwell Parker said: 1 pair variable damping rear shock absorbers from a BMW 5 Series touring F11. Part nos 37.12 - 6796985 + 37.12 - 6796986 These are in good working order with no leaks or damage and have covered 80000 miles so plenty of life left in them. Selling as a matched pair. Some surface corrosion but nothing major. Slight corrosion on the tops of the damper rods but doesn't affect operation. Just to point out in case you're not aware these will require coding to the car. £550 inc Royal Mail 48hr postage Happy to upload more photos if needed. Just ask 😀 Still available? Quote Link to comment Share on other sites More sharing options...
