MikeTheSmith Posted May 10, 2023 Share Posted May 10, 2023 Does anyone have any tips on how to replace the hard lines? I've removed the passenger side from engine bay to flexi connector at the rear but had to cut it at the bottom of the rear arch to remove it. The plan is to replace with CuNi but just wondering if anyone has done this before with the rear beam in place - it seems very tight to feed a pipe through up and over. Thanks! Quote Link to comment Share on other sites More sharing options...
Keliuss Posted May 11, 2023 Share Posted May 11, 2023 I replaced all the brake lines at the rear with the subframe in place. Car on jack stands on the driveway too lol. Awkward but doable. The rest of the lines were ok, so just put a coupler before the rear arch and replaced all behind. Used CuNi also. Same goes for fuel lines. All replaced with subframe in place but again used pipe couplers to make shorter sections which makes life easier. Keliuss Quote Link to comment Share on other sites More sharing options...
