Apples12 Posted April 2, 2023 Share Posted April 2, 2023 Hi all Looking to fit a dashcam to my g30 and just wondering if there's any clear to follow guided for rhd cars? Is the fusebox located under the steering column or is it behind the glovebox like on the f10? Quote Link to comment Share on other sites More sharing options...
JCP Posted April 3, 2023 Share Posted April 3, 2023 My G31 it was right side below the steering column on the right side. Fiddly to get at. Quote Link to comment Share on other sites More sharing options...
Matthew Posted April 6, 2023 Share Posted April 6, 2023 Use fuse F59 in the fuse box under the steering column on RHD cars. It should be unoccupied but has 12v when the ignition is on and for about 10 minutes after the car shuts down. Quote Link to comment Share on other sites More sharing options...
