VPCAPTAIN Posted April 1, 2023 Share Posted April 1, 2023 Hi spotted some staining on the undertray and found a leak on the the rear of the gearbox at the driveshaft oil seal. as an interim until I can replace the seal wanted to check the gearbox fluid level and change out the existing gearbox oil and top up fully the gearbox with fresh fluid. found a few good you tube guides to start but any help on best manual gearbox fluid and best method to refill once drained would be appreciated thanks Quote Link to comment Share on other sites More sharing options...
duncan-uk Posted April 3, 2023 Share Posted April 3, 2023 The top tip is make sure the fill plug is free and can be undone before draining. 1 Quote Link to comment Share on other sites More sharing options...
Sir Anthony Regents Park Posted April 3, 2023 Share Posted April 3, 2023 (edited) 😀 Edited April 9, 2023 by Sir Anthony Regents Park 1 Quote Link to comment Share on other sites More sharing options...
