A2EEM Posted March 26, 2023 Share Posted March 26, 2023 My 2017 G30 530i has recently started to jerk/hesitate at low speeds (up to 25 mph). At first it would only do this in ECO mode but now it also does it in Comfort mode. The jerking only happens once the engine is warm. Anyone else had a similar issue or can direct me to the issue? Quote Link to comment Share on other sites More sharing options...
Matthew Posted March 26, 2023 Share Posted March 26, 2023 6 hours ago, A2EEM said: My 2017 G30 530i has recently started to jerk/hesitate at low speeds (up to 25 mph). At first it would only do this in ECO mode but now it also does it in Comfort mode. The jerking only happens once the engine is warm. Anyone else had a similar issue or can direct me to the issue? Read fault codes as a starting point. Quote Link to comment Share on other sites More sharing options...
