Syncrofred Posted March 20, 2023 Share Posted March 20, 2023 Out and about this morning, all normal. Signalled to turn into our drive and nothing on the dash and no 'click' noise. Checked when parked and the outside indicators are flashing, but nothing inside the car to tell me that they are working. Any Ideas? Quote Link to comment Share on other sites More sharing options...
Syncrofred Posted March 24, 2023 Author Share Posted March 24, 2023 Thanks for the overwhelming response to my problem. A couple of hours later the indicators were normal again when I went out. I stopped and tried to open the tailgate. It's a powered one. The lock unlatched, but the pump didn't turn on, so the tailgate didn't lift and I had to do it manually and hold it open. Then when I closed it again it didn't latch. I drove home and found the central locking didn't work! I went and had lunch. Later I disconnected the battery for a few minutes and everything returned to normal, save for the indicators. The following day they had magically repaired themselves. Since then no problems. Weird or what. I'm thinking Body Control Module, but it's only a guess and I don't know where it lives anyway. My son (Flandy on here) used his diagnostic tool, but it didn't show anything that looked relevant. Quote Link to comment Share on other sites More sharing options...
dj123 Posted March 24, 2023 Share Posted March 24, 2023 This is general discussion, rather than the technical area for your car for these queries to be placed. Quote Link to comment Share on other sites More sharing options...
E39M5 Posted March 25, 2023 Share Posted March 25, 2023 Had the same thing myself, in my case was lcm Quote Link to comment Share on other sites More sharing options...
Dbcrd Posted March 26, 2023 Share Posted March 26, 2023 On 24/03/2023 at 15:58, Syncrofred said: Thanks for the overwhelming response to my problem. A couple of hours later the indicators were normal again when I went out. I stopped and tried to open the tailgate. It's a powered one. The lock unlatched, but the pump didn't turn on, so the tailgate didn't lift and I had to do it manually and hold it open. Then when I closed it again it didn't latch. I drove home and found the central locking didn't work! I went and had lunch. Later I disconnected the battery for a few minutes and everything returned to normal, save for the indicators. The following day they had magically repaired themselves. Since then no problems. Weird or what. I'm thinking Body Control Module, but it's only a guess and I don't know where it lives anyway. My son (Flandy on here) used his diagnostic tool, but it didn't show anything that looked relevant. Depends what diagnostic tool he used. Generic diagnostic tools probably won't show up. It would need something like INPA. The other thing that occurs to me if it isn't a module is the tailgate wiring. A known problem. Failing wires can be intermittent at first. Quote Link to comment Share on other sites More sharing options...
Flandy Posted March 27, 2023 Share Posted March 27, 2023 I think it was just suffering from electrical indigestion, because having burped it, it seems to be fine now. Quote Link to comment Share on other sites More sharing options...
Syncrofred Posted March 29, 2023 Author Share Posted March 29, 2023 Behaved perfectly for a couple of days, then the faults returned. If it is one of these 'modules', where will find them? Presumably they have a part number on them. Quote Link to comment Share on other sites More sharing options...
Syncrofred Posted March 30, 2023 Author Share Posted March 30, 2023 Today they have repaired themselves again. Several fault codes logged that refer to K-Bus problems, but still a bit confusing. Quote Link to comment Share on other sites More sharing options...
