olliecampbell Posted February 3, 2023 Share Posted February 3, 2023 3 hours ago, Tallman85 said: Today: 1) I just put a bottle of injector cleaner in the tank...lets hope it will smoothen the idle. 2) I just took it to a garage and did the wheel alignment ... my rear left wheel was 3 degrees out! it looked odd from when i bought it, but i did not realize it was that bad! Now all green and nice! 3) I have 3 out of 6 glow plugs that are down 😞 i think it hurts the DPF correct? what brand should i go for NGK or Bosch? Thx. I've got 5 out of 6 down :D I've always read it's best to go with Bosch and to get the WD40 on them as soon as possible before you start so it gets a chance to work....and do it when the engine is hot! A bad start to the week for me.....CCV changed and an oily vessuvious in the engine bay.... Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 3, 2023 Author Share Posted February 3, 2023 Yes i saw that...oil is so messy...what a pain to clean. Is it a difficult job to take out the manifold? to change the plugs? i am tempted to do it myself. Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 3, 2023 Author Share Posted February 3, 2023 i am confused which one is for our diesel engines? Quote Link to comment Share on other sites More sharing options...
Changy Posted February 3, 2023 Share Posted February 3, 2023 49 minutes ago, Tallman85 said: i am confused which one is for our diesel engines? The middle one; 5 volt. Quote Link to comment Share on other sites More sharing options...
Changy Posted February 3, 2023 Share Posted February 3, 2023 3 hours ago, Tallman85 said: Is it a difficult job to take out the manifold? to change the plugs? i am tempted to do it myself. No, it's straightforward, but have a look at some videos online to prepare yourself for the job. You need the engine hot if possible and use some Plus Gas or similar. Take your time if one is stuck; undo it, then tighten, then undo again to try and ensure the threads are free. Quote Link to comment Share on other sites More sharing options...
Changy Posted February 3, 2023 Share Posted February 3, 2023 1 minute ago, Changy said: No, it's straightforward, but have a look at some videos online to prepare yourself for the job. You need the engine hot if possible and use some Plus Gas or similar. Take your time if one is stuck; undo it, then tighten, then undo again to try and ensure the threads are free. @Gonzo advised me to use a torque wrench set at approx. 30nm. I would ask him to confirm the torque value so you are below the snapping value. Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 3, 2023 Author Share Posted February 3, 2023 Thank you for the info - Bosch specify 15Nm as Torque. But engine needs to be cold when the new ones go in right? as otherwise if I tighten when hot, when it cools off, the stresses will increase and result in more Nm? or i am too theoretical 🙂 Quote Link to comment Share on other sites More sharing options...
Changy Posted February 3, 2023 Share Posted February 3, 2023 3 minutes ago, Tallman85 said: Bosch specify 15Nm as Torque. That is tightening torque; I am sure @Gonzosaid the snapping torque is 30nm, but I am sure he will pop in and confirm. You are being too theoretical with the cold engine comment. If you torque them at 15nm, the temperature will not alter the amount of force. You need a hot engine when removing them because the head expansion increases the chance of loosening them without a breakage. Quote Link to comment Share on other sites More sharing options...
Changy Posted February 3, 2023 Share Posted February 3, 2023 9 minutes ago, Tallman85 said: Thank you for the info - Bosch specify 15Nm as Torque. I checked TIS and BMW specify 13Nm. Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 3, 2023 Author Share Posted February 3, 2023 1 minute ago, Changy said: That is tightening torque; I am sure @Gonzosaid the snapping torque is 30nm, but I am sure he will pop in and confirm. You are being too theoretical with the cold engine comment. If you torque them at 15nm, the temperature will not alter the amount of force. You need a hot engine when removing them because the head expansion increases the chance of loosening them without a breakage. Correct - that is tightening torque. ok now I understand - a torque wrench to remove them…good idea. Gonzo is ‘semi-retired’ so probably he is somewhere in a middle of a beach in the Bahamas 😂😂 Quote Link to comment Share on other sites More sharing options...
Changy Posted February 3, 2023 Share Posted February 3, 2023 10 minutes ago, Tallman85 said: Gonzo is ‘semi-retired’ so probably he is somewhere in a middle of a beach in the Bahamas 😂😂 I'm fully retired, but sadly I am not on a beach 🤣 2 Quote Link to comment Share on other sites More sharing options...
Changy Posted February 3, 2023 Share Posted February 3, 2023 I washed and polished the old girl today. I also bought a new driver's side floor mat. Quote Link to comment Share on other sites More sharing options...
Gonzo Posted February 4, 2023 Share Posted February 4, 2023 Breaking torque I set to 30, tighten to 13 1 Quote Link to comment Share on other sites More sharing options...
thomp1983 Posted February 4, 2023 Share Posted February 4, 2023 Picked it up from bodyshop who've had it for a week to refurb the wheels, respray the tailgate as I reversed it into something and repair a small parking graze on the front bumper that the wife did. 1 Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 5, 2023 Author Share Posted February 5, 2023 8 hours ago, thomp1983 said: Picked it up from bodyshop who've had it for a week to refurb the wheels, respray the tailgate as I reversed it into something and repair a small parking graze on the front bumper that the wife did. That is a nice looking e61 mate. That is the colour I wanted but i was slow to react when there was one for sale… Can you please share with us the wheels specs? Size / offset ? And tire sizes? thx Quote Link to comment Share on other sites More sharing options...
thomp1983 Posted February 6, 2023 Share Posted February 6, 2023 Not sure which wheels they are, they were on my old e60. Rear tyres are 275/30/19 offset is 20 and there a 9 inch rim with 20mm spacers Front tyres are 245/35/19 offset is 18 and there an 8 inch rim with no spacers. I may get spacers for the front at some point.as there a bit tucked in compared to the rears. Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 6, 2023 Author Share Posted February 6, 2023 2 hours ago, thomp1983 said: Not sure which wheels they are, they were on my old e60. Rear tyres are 275/30/19 offset is 20 and there a 9 inch rim with 20mm spacers Front tyres are 245/35/19 offset is 18 and there an 8 inch rim with no spacers. I may get spacers for the front at some point.as there a bit tucked in compared to the rears. Yeah I thought they were 19s .. they fill the arches so nicely. They seem to be similar to spiders. Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 13, 2023 Author Share Posted February 13, 2023 Today i replaced my battery. It was a cheap unbranded one and the wrong type. It was causing all kind of electronics errors on start ups…etc. I now bought a proper Bosch 95Ah AGM and registered it with ISTA too. So far so good…I actually wanted a Varta but it was out of stock! 1 1 Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 14, 2023 Author Share Posted February 14, 2023 Today my bmw glove-box torch arrived 🙂 … and now in place! 1 1 Quote Link to comment Share on other sites More sharing options...
Gonzo Posted February 15, 2023 Share Posted February 15, 2023 I fitted a thing today... Quote Link to comment Share on other sites More sharing options...
Changy Posted February 15, 2023 Share Posted February 15, 2023 19 minutes ago, Gonzo said: I fitted a thing today... That looks more like a thingymajig than a thingy 😃 Quote Link to comment Share on other sites More sharing options...
olliecampbell Posted February 15, 2023 Share Posted February 15, 2023 Today.....I did nothing because I'm broke, but I lived vicariously through you guys :) 1 Quote Link to comment Share on other sites More sharing options...
Tallman85 Posted February 15, 2023 Author Share Posted February 15, 2023 Damn, I felt a king yesterday because I installed the factory torch 😂😂 …now i see this… nice upgrade Gonzo….that comes up as a kit or Gonzo-Custimazation? Preparing for Nurburgring mate? Quote Link to comment Share on other sites More sharing options...
Gonzo Posted February 16, 2023 Share Posted February 16, 2023 (edited) 18 hours ago, Tallman85 said: Damn, I felt a king yesterday because I installed the factory torch 😂😂 …now i see this… nice upgrade Gonzo….that comes up as a kit or Gonzo-Custimazation? Preparing for Nurburgring mate? No room for a torch in mine as the CIC uses that hole for the USB plug... Nah, no intention of racing the car, this is a comfort mod if anything mate. Many years ago the original owner of my mates car fitted this, it then got imported from Japan and as he's selling it, well I wanted it, so I took it off his hands 🙂 Edited February 16, 2023 by Gonzo Quote Link to comment Share on other sites More sharing options...
oldjohnny Posted February 16, 2023 Share Posted February 16, 2023 Just like Tallmans post on Monday, I fitted a new Exide Premium Carbon Boost battery, whatever all that means. I went down the road of connecting the underbonnet terminals to another good battery before disconnecting the old one to keep everything going as normal. When I eventually find someone to check for registration I will do so. It was a bit of a struggle removing the old one due to all the wiring, but I covered the connectors after disconnecting and taped them up out of the way. I'm the wrong side of 70 now and I certainly felt it when lifting one out then one in. There's hardly any turnover now, almost instant ignition. The almost 20 year old late 2003 530d lives on for another while. 1 Quote Link to comment Share on other sites More sharing options...
