Bavarian Cortina Fan Posted November 21, 2022 Share Posted November 21, 2022 I’m sure there were threads on this on the old site, but now the dark nights have arrived, I took the plunge and bought a cheap HID kit off fleabay. I fitted an H4 kit to a Honda back in the day so I’m happy with the concept of fitting HID ballasts and canbus error surpressors etc However it’s a pig of a job on an F10 as it’s wheelarch liner out - can’t access from the engine bay top and restricted access through the bulb flap. Anyway what’s confused me is that the new cheap bulbs provided have a plastic base, and look nothing like the H7 halogen bulb I removed. So locating the new bulb is all down to the crappy twist clip that attaches to the bulb holder-like the pic attached. You can’t reuse the old clips on HID bulbs as they won’t fit over the new HID sub harness/grommets. And no new clips were included in the new kit. So I assume it’s a case of cutting the old clips to prise them over the harness by the bulb holder??? Anyone been here before ? Cheers Quote Link to comment Share on other sites More sharing options...
bmwmike Posted November 21, 2022 Share Posted November 21, 2022 (edited) Off advice on here I bought a kit on eBay and specific clips and it worked a treat. Fwiw I mounted mine from above by removing the plastic covers above each wing/arch. Easy and invisible. If I was doing it again I'd whip a wheel off and remove the liner. If you've a driver / drill it's really not hard to get the liner out and back in a again. Night and day difference compared to halogens. edit not sure if those are the clips I used and it was a bit of a pig to get them in, easier with wheel off, but once in they were fine. Edited November 22, 2022 by bmwmike Quote Link to comment Share on other sites More sharing options...
Bavarian Cortina Fan Posted November 22, 2022 Author Share Posted November 22, 2022 Cool thanks Did the clips look like this? Funky little cut out - so you can pop them over the new harness… Can’t believe a car like a 5 uses these prehistoric tin bulb holders…😅 Quote Link to comment Share on other sites More sharing options...
bmwmike Posted November 22, 2022 Share Posted November 22, 2022 Yep those ones Quote Link to comment Share on other sites More sharing options...
